Thread: Help on DWV Diagram
    DIY Member Drewski123's Avatar
    Aug 2011
    Seattle
    Default Help on DWV Diagram
    Can the tub drain use the DWV 3" vent? The distance between the tub and the DWV 3" vertical part is less then 15". Or, it has to vent using its own 1.5" vent, and then the 1.5" vent would merge with the 3" vent in the attic?
    Name:  DWV Diagram.jpg
    You can't run a toilet down a tub vent in Seattle, or anywhere.
    You will need to run a 1.5" vent between the tub p-trap and the stack and then either go through the roof, or revent at 42" above the floor.
    Aug 2011
    Seattle
    Thanks Terry. My initial plan was to run the 1.5" vent, but wanted to make sure.
    Just "running" a 1 1/2" vent is NOT enough, it has to be run CORRECTLY.
  1. Please give a look at this diagram. THX!
    By Geoff Clogan in forum Remodel Forum & Blog
    Last Post: 12-14-2010, 09:56 AM
  2. Plumbing Diagram Help
    By bdaub in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-01-2010, 08:36 AM
  3. Please comment on my DWV diagram
    By mjsmith0 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-17-2009, 02:00 PM
  4. Want toilet diagram
    By pks71 in forum Toilet Forum discussions
    Last Post: 04-11-2005, 03:17 PM
  5. Attic Bath Diagram
    By jasonmcl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-25-2005, 05:10 AM
