Results 1 to 5 of 5
Thread: Water Heater Connections
    DIY Junior Member Odie130's Avatar
    Oct 2011
    Oklahoma
    Default Water Heater Connections
    Attempting to remove copper pipe from water lines which are plastic. The problem is I cannot separate them. The copper pipe will turn freely but will not come apart from plastic fitting.
    That's right. It's a Uponor PEX fitting.
    You will need to cut the tubing and then reconnect them.
    Dec 2009
    northfork, california
    Except you will need to have the special tool or homeowner connector device ready before you cut.
    Normally a water heater has 24" of metal piping before you convert over to PEX or CPVC.
    Being that is the case, we use 24" flex connectors, either copper or stainless steel. Not the braided supplies, but the corrugated supplies.
    Yakima WA
    Those flex connectors are really the DIYers friend when it comes to water heater connections to any kind of pipe!
  1. Replies: 6
    Last Post: 10-01-2010, 07:06 PM
  2. piping connections to water heater
    By Steve_P in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-31-2010, 06:27 PM
  3. Water Supply Connections
    By mdk in forum Water Heater Forum, Tanks
    Last Post: 04-09-2010, 06:51 PM
  4. Water level sensor connections
    By dubman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-18-2009, 05:10 AM
  5. Hot Water heater Connections
    By pilotboat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2007, 07:15 PM
