Results 1 to 15 of 38
Thread: Changing shower tub trim and need help! Powers 410 Hydroguard
Hybrid View
    DIY Junior Member angel9894's Avatar
    Oct 2011
    NYC
    Default Changing shower tub trim and need help! Powers 410 Hydroguard
    I am doing a remodel of my bathrooms and want to change the showerheads, spouts and control levers in my 2 full bathrooms. I brought in a few contractors who said we "HAD" to do all this extensive stuff and long story short quoted anywhere from 6-10k just for the plumbing (NYC pricing, ha!) This is a highrise building and doing anything with opening up walls is a pain and expensive!
    So I then had the maintenance guy from my building come in since he is doing a bunch of work on the side for us (installing new toilets, light fixtures, vanities etc), and he said that it's NOT necessary to do anything with the plumbing, I can just change out the trim with any trim kit I find that I like.
    So here is my question:
    Currently the showers use these "Powers Hydroguard 410" lever controls Name:  044.JPG
Size:  82.3 KBName:  042.JPG
Size:  44.1 KBName:  086.JPG
Size:  62.4 KBName:  085.JPG
    He said they have a brass valve and he can supply any of the valves needed and any standard trim kit should work. I want to buy a mid-range Kohler trim set to replace these fixtures with. I know ideally it would be better to change out the whole shower body, but we simply don't have the kind of money it costs to do it right now.
    What do I need to look for in a trim set to replace this? Should I still buy a kit that has a valve or no need. I'm looking for something on ************.com but confused.
    Any help would be greatly appreciated to this total newbie!
    Your handyman doesn't seem to have a clue about the valve and the trim for it.
    You have to use the trim that is made for the valve in the wall. Either that, or change the valve in the wall.
    What is standard, is the shower arm. That threads into a 1/2" female fitting in the wall, so any standard shower arm, or shower head will work.
    The tub spout is also a standard 1/2" pipe thread.
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    You can replace a valve by using a reno plate, basically you open up the tile and replace the valve then use the plate to cover the larger hole that you made. For a pro your looking at about 2 hours. Thats not what the handy man in your bulding is LOL! What happens when he causes a leak and floods out the building? I would go with a licenced plumber who knows what he's talking about.
    Oct 2011
    NYC
    Not to defend him as I have no dog in this fight, but he isn't a "handyman". He is a union member licensed plumber and electrician in NYC and one of the 20 year Maintenance men for the building who handles all the building and electrical plumbing. Maybe he didn't know exactly what I was asking via telephone, or rather, maybe I misunderstood what he was telling me.
    I just checked and I found the updated version of those old Powers ones and it was over $400.00 just for the lever replacement.
    Name:  Powers PB410.jpg
    So is there no Kohler or Grohe or nice replacement I can buy?
    As for opening up the tile and replacing the valve, opening up the tile does not = opening up the wall does it? My building requires a 5k deposit to do anything that requires opening walls.
    Again, thanks for you patience with me!
    Oct 2011
    NYC
    So excluding the lever/valve issue, I can replace the Shower Head and the tub spout with most standard ones?
    We are renting the apartment out and my Dad's given me a tiny budget so I have to find ways to update the bathrooms at minimal cost
    If your guy has done it, then let him find the parts.
    That's not how it works in the rest of the world though. For the rest of us, you would normally find parts that mate up.
    Manufacturers don't make parts that interchange.
    I also can't use Toyota parts in my Mitsubishi.
    The picture you posted shows a complete valve with trim. Can you buy just the trim?
    And if you go to the Powers web site, you should be able to contact their tech support and they should know your options. That has to be a common question for them.
    Oct 2011
    NYC
    Thanks Terry!
    I submitted a tech support request to them 2 days ago asking this question, which I'm sure you're right, must be common! Unfortunately, nothing heard back yet.
    In the meantime, am I ok to go ahead and at least buy new shower heads and spouts?
  1. Powers e700 series shower faucets?
    By toebone51 in forum Shower & bathtub Forum & Blog
    Last Post: 05-09-2011, 06:15 PM
  2. changing old shower handle trim
    By aobellis in forum Shower & bathtub Forum & Blog
    Last Post: 03-07-2009, 05:13 PM
  3. shower knob broke and Powers is brand name
    By winewood in forum Shower & bathtub Forum & Blog
    Last Post: 11-16-2007, 12:23 PM
  4. New shower trim wallplate doesn't cover shower wall hole
    By ax77 in forum Shower & bathtub Forum & Blog
    Last Post: 12-02-2006, 08:51 PM
  5. Changing trim to whirlpool tub
    By KBalon in forum Shower & bathtub Forum & Blog
    Last Post: 06-14-2005, 04:21 PM
