Results 1 to 5 of 5
Thread: Toto Aquia and Unifit?
    Default Toto Aquia and Unifit?
    Is the Aquia compatible with Toto's Unifit adapter? My rough-in is 10" and I'd hate to change it...
    Also, is there a PDF installation manual available for the Aquia? I've seen some for other Toto toilets, but not the Aquia. I'm mostly interested in how the toilet is screwed to the floor - I assume it doesn't use only the flange bolts?
    Default Aquia rough-in
    The Aquia uses it's own adapter.
    While the Unifit has the toilet dropping straight down into the top of it,
    The Aquia adapter slides in from the front.
    In addition to the adapter, two plastic blocks are screwed to the floor, and the mounting screws that you see in the picture thread into these.
    The toilet is quit snug to the floor this way.
    I'm not aware of adapters for the Aquia that allow a change of rough-in.
    You should be able to get by with 11-1/2" or more for the rough-in.
    Thanks, Terry!
    Ah, I see. I was wondering how those side-mounting bolts worked...
    One other thing - I have an odd situation in that I have some radiant tubing running along side the toilet, within inches of the toilet flange.
    Can you tell me the location of the plastic blocks you mention, in relation to the drain/flange?
    I live in Seattle - do you have these toilets in stock? If not, how long to get them?
    I have them in stock.
    I don't see how you would be able to install one with a 10" rough-in though.
    The blocks mount closer to the wall than the flange.
    http://www.easycarts.net/ecarts/terr...s.html#CST414M
    Well, I'll have to change the rough-in to 12". Not the end of the world.
    Thanks Terry. We'll give you a call to order 1 or 2 of these after Thanksgiving.
