Thread: HVAC Wiring
    DIY Junior Member charp's Avatar
    Jul 2011
    Grass Valley, CA
    Default HVAC Wiring
    The HVAC unit (LP gas furnace) is made by Bryant around 1990 and was wired with a flat, black insulated wire with two 8 gauge conductors and a small ground. Shouldn't it be wired with 8/3 with ground? I have to remove some decking to access the disconnect box mounted on the wall by the unit to see what kind of wire runs between the unit and the disconnect box. Yes, some bright person actually built a deck right over the unit and covered the shutoff box! I should post a picture of the original Zinsco subpanel to really scare y'all.
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    if you are talking about an a/c unit that is run off of 220v, all you need is two wire w/ground since the neutral is not used.
    Jul 2011
    Grass Valley, CA
    It's an all in one unit, AC/gas furnace/fan, installed outside the house. I have some 8/3 that I can use to reach the new subpanel, I just won't use the neutral. Thanks
    The installation manual would indicate if it needs a neutral (which would allow some internal 120vac circuits/devices), but it probably doesn't need it.
  1. DIY HVAC Equip. Where?
    By Lakee911 in forum HVAC Heating & Cooling
    Last Post: 12-12-2009, 06:21 PM
  2. Maytag HVAC
    By weather777 in forum HVAC Heating & Cooling
    Last Post: 10-21-2008, 06:33 PM
  3. Diy Hvac
    By v10rick in forum HVAC Heating & Cooling
    Last Post: 07-02-2007, 01:38 PM
  4. HVAC remodel
    By franktaylor in forum HVAC Heating & Cooling
    Last Post: 02-16-2007, 08:57 AM
  5. HVAC questions
    By DIY in forum HVAC Heating & Cooling
    Last Post: 01-30-2007, 09:13 AM
