Results 1 to 9 of 9
Thread: How much FLEX in Pex
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default How much FLEX in Pex
    I don't have ANY pex at home nor am familiar with the material ......am doing some planning on my excel grid this morning.
    How much FLEX does pex have.
    I'm considering ordering HW baseboards with the pipeing in the back of the unit . The units get hung onto cleats that attach to the wall. Standard piping on these baseboards are sides and bottom. I have some of these baseboards....and it's piped to the sides with trim covers that cover the pipework.
    I'm not sure how much my RO for the heating will change but just checking in on how much FLEX pex has, as the theory will be that I connect the PEX to the baseboard,
    Plumber jimbo's Avatar
    You should get the design/install manual for the brand you are using, such as this: http://www.uponor.ca/~/media/Files/T...spx?sc_lang=en
    In this case, Uponor specifies minimum bend radius of 6X OD.
    You will NOT be able to bend the PEX and connect it directly to the baseboard inside the trim covers. You sweat elbows with adapters, or adapter elbows, to the baseboard and the PEX to that.
    Jun 2006
    Correct. It will be a thread adapter on the *back* of the unit and then the pex from there ---back to to current black pipe in which I will be removing the old baseboards and will probably also end up cutting shorter and rethreading.
    http://www.runtalnorthamerica.com/re...eboard_uf.html
    My current runtels are piped on the side and then trim covers cover it. It makes this $$ baseboard look like crap cause the trim covers are hideous.
    Master Hot Water Mpls,MN BadgerBoilerMN's Avatar
    Mar 2011
    Minneapolis
    The bend radius of PEX tubing is determined by the size and type of PEX. Once you have the spec. which, would naturally include an oxygen barrier, you will have the bend radius. Runtal will void you warranty if non-barrier PEX is used.
    The type of pex will determine the bend radius. Type -A is the most flexible and can support the smallest bend radius. To get and hold a neat bend, they do make a curved bracket you thread the tubing into. It is the best way to get a minimum radius bend without risk of crimping the tubing.
    DIY Member techinstructor's Avatar
    Apr 2009
    North Carolina
    We're getting ready to install a Pex homerun system with a Manabloc, so we also are struggling with the flexibility issue. Viega Pex has a bend radius of 8 times the pipe diameter or 4" for 1/2" pipe. We bought the 100' roll of Pex so the pipe has a curved "set" in it. We're finding that whether you straighten or bend the tube, it wants to return to its original curve. Can Pex be heated with a heat gun? Will it this take a set at the new angle? I've seen both plastic and metal bend supports, but these are not useful since we are also planning to insulate the Pex to control condensation and conserve heat. I would appreciate any tips anyone has on bending the tubes.
    Jun 2006
    I must has misworded it.
    Behind the baseboard, there is at least 6" + room back there.
    The goal is to just run the short loop of pex out the wall, connect it back to the baseboard from the back - and then *hang the baseboard* onto the cleat.
    The goal is not connect the baseboard on the side taps or bottom - for a nonexposed install of the loops.
    Should be plenty of room that when I *push the pex* into the wall, it just needs some give to curve.
    I'm not talking some really sharp bend radius or anything..
    PEX is about as flexible as a stiff (non-rubber) garden hose. You can get the play you need by either offsetting the supply tap and baseboard connection about 1-1/2 to 2', or using 3-4' of pex to make a loop.
  1. Compression va Flex Lines
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-29-2010, 09:44 AM
  2. Flex lines - code?
    By dx in forum Water Heater Forum, Tanks
    Last Post: 10-27-2009, 02:20 PM
  3. Flex Conduit as ground
    By M3 in forum Electrical Forum discussion & Blog
    Last Post: 03-01-2009, 02:15 PM
  4. Gas flex line in a wall?
    By Solan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-19-2008, 05:28 PM
  5. Capacity of 1/.2 Flex
    By seaneys in forum Electrical Forum discussion & Blog
    Last Post: 07-21-2007, 11:49 PM
