Proper settings Enertrol
GregoryR
Maine, USA
Hello,
Could any of you help me with setting this thing (outdoor reset) up properly? People on this site were a real good help last time I had questions, and I thank all of you for your time.
Tom Sawyer
Maine
Set the slide switch to mod and turn the dial to 160 to start. You're up here in Maine with me so, when it gets damn cold out, if the house won't heat, turn the dial up 20 degrees until it will. You can also try going lower if the house is heating ok. The dial is what sets the temperature differential between outside temp and boiler supply temp, adjusted for degree days. I found that 160 to 180 seems to work pretty good around here.
GregoryR
Maine, USA
Done and done, thanks so much. Hopefully we'll see some savings now that this thing is actually doing its job.
