Results 1 to 2 of 2
Thread: PC to ABS: Fernco or solvent weld?
    Product R&D for a powertool manufacturer dgold's Avatar
    Dec 2006
    Carlsbad, CA
    Default PC to ABS: Fernco or solvent weld?
    Below is a pic of the drain pipe under my master bath vanity. My drain pipes are made of ABS.
    About a 1/4" from the face of the escutcheon, someone has previously welded a straight coupling, and for God knows what reason, the trap has been glued together.
    I am installing a new base cabinet and top, and the drain needs to be repositioned.
    Should I cut along the yellow line, remove the escutchion, and slip on a Fernco coupling?
    Or can I make a cut a little further out, and solvent-weld a PVC street coupling into the inner ABS pipe?
    Orange has an "all-purpose" cement which works on both ABS and PVC, but it doesn't say on the label if it's okay for to welding together two different plastics together.
    Just trying to ascertain a legitimate way to do this - preferably without tearing into the wall.
    Thanks in advance,
    David
    Name:  Master vanity drain.jpg
    Not a pro, but happy to share my lessons learned whenever I can. This forum has been a fantastic resource along the way.
    Jun 2009
    Canada
    There is a transition glue available, but in your case I wouldn't use it.
    Cut on that yellow dotted line, and lose the bell-escutcheon, bore out the back of the cabinet enough to fit a new ABS coupling.
    I'd be tempted to use a spigot-trap adapter, and use a tubular trap so you can avoid problems like this later on.
  1. jb weld?Toilet tank crack
    By cwhyu2 in forum Toilet Forum discussions
    Last Post: 03-09-2009, 05:51 PM
  2. jb weld?Toilet tank crack
    By cwhyu2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2009, 10:05 PM
  3. Re- gluing ? re-melting PVC w/ pvc solvent
    By pitterpat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2009, 05:03 PM
  4. Solvent weld tub drains
    By tomcat22 in forum Shower & bathtub Forum & Blog
    Last Post: 10-15-2008, 07:18 AM
  5. Solvent Weld vs No Caulk
    By Blaze in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2007, 06:06 AM
