Results 1 to 6 of 6
Thread: NC, Greene Co: how far off ground does outdoor receptacle have to be...
    DIY Junior Member itr674's Avatar
    Dec 2009
    NC
    Default NC, Greene Co: how far off ground does outdoor receptacle have to be...
    I'm getting ready to run wiring for five outdoor receptacle and am wondering how far off the ground they must be?
    Jun 2007
    North Carolina
    That all depends on how high you want them mounted. There is nothing that mandates how high.
    It might be prudent to keep them out of the 'splash' zone (the area where rainfall splashes back up after running off the roof) and above the normal snow load (probably not a consideration in warmer states). Then, I don't like to have to lean over too far, either!
    Dec 2009
    NC
    thanks, I think I will plan on 24" above mulch then...
    Jun 2007
    North Carolina
    Quote Originally Posted by itr674 View Post
    18 to 24 inches is what just about everybody around here mounts them. Be sure to mount them so they aren’t easily broke off. I use a 4x4 post installed at least 24 to 36 inches deep to hold them in place.
    Also remember that PVC boxes and pipe will fracture easily when cold. If using PVC I highly recommend using 80 instead of 40 and nothing smaller than inch for its strength.
    There's no minimum height requirement for recepticals in residential applications. The only requirements are that for each dwelling at grade level there is one receptical accessible not more than 6.5" at the front and back of the dwelling.
    Mountain Eagle
    DIY - sure I'll try anything
  1. No Ground for Outdoor Lights
    By hormy_83 in forum Electrical Forum discussion & Blog
    Last Post: 09-16-2009, 06:25 AM
  2. Single receptacle to a double receptacle
    By beeger11 in forum Electrical Forum discussion & Blog
    Last Post: 05-02-2009, 06:01 PM
  3. What would magnetize a receptacle?
    By Taylor in forum Electrical Forum discussion & Blog
    Last Post: 10-06-2008, 01:39 PM
  4. Changing receptacle
    By tlong_66 in forum Electrical Forum discussion & Blog
    Last Post: 04-09-2008, 07:16 PM
  5. How to tap off a receptacle
    By jar546 in forum Electrical Forum discussion & Blog
    Last Post: 02-26-2008, 07:03 PM
