Results 1 to 7 of 7
Thread: Branch drain sizing
    DIY Junior Member Aaa123's Avatar
    Oct 2011
    Colorado
    Default Branch drain sizing
    Hello,
    Would you please answer the following:
    1) The '06 IPC, if I interpret table 110.1 and 110.2 correctly, states: a lav is worth 1 unit, a kitchen sink w/disposer and dishwasher is worth 2, and a clothes washer is worth 2. All combined, that's 5, and a 2" branch line can handle up to 6 units. Do I understand this correctly and Are these numbers the same for the '09 IPC?
    2) The iron I'm replacing has no clean-out and there is no practical place that I can put it. (In fact, local plumbers are frequently seen stuffing cable down vents.) Can I extend my branch beyond the fixtures and install a horizontal, overhead clean-out? I didn't notice anything in the '06 that would prevent it.
    Aug 2009
    South*East
    If the line is over 18" and not serving a fixture it is considered a dead end which is not allowed.
    John
    Oct 2011
    Colorado
    Hi John and thanks!
    When you say 18", does that refer to the full length of the branch or the distance between the nearest fixture junction and the (proposed) clean-out?
    Oct 2011
    Colorado
    Are these questions in the wrong forum? I am hoping to avoid a long trip to the main library.
    Aug 2009
    South*East
    Quote Originally Posted by Aaa123 View Post
    Hi John and thanks!
    The distance between the nearest fixture junction.
    John
    Oct 2011
    Colorado
    Thank you.
    I take your silence on the line size to be agreement?
    Plumber Winslow's Avatar
    Dec 2005
    Hawaii
    Fixtur unit values never change, with the exception of the water closet because of it's water usage being reduced considerably.
    Why can't you put the cleanout under the sink or on the washer?
  1. Sizing sump pit for external french drain
    By Teehee99 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-15-2010, 07:46 PM
  2. Need Help !!! - French Drain/Pump Basin Sizing
    By turnkey in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-20-2009, 08:38 PM
  3. General - Trunk to branch sizing?
    By sahayda in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-05-2008, 06:03 AM
  4. main drain line sizing?
    By mporterf in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-20-2008, 10:31 PM
  5. Chronic Tub and Branch Drain Clogging
    By bet3z in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2006, 08:23 AM
