Results 1 to 2 of 2
Thread: Stuck Tub Spout & Drain Flange
Hybrid View
    DIY Junior Member katharine's Avatar
    Oct 2011
    Chicago
    Default Stuck Tub Spout & Drain Flange
    Hi All....I'm in the process of remodeling my bathroom and I can't get the tub spout off to save my life. It has 45 yrs of hard water deposits etc. It is a screw off type. Any tips for me to get it off without damaging the pipe? It does spin counter clockwise right?
    Also...the drain flange also won't budge. All I have are 2 nubs inside the drain to use to spin it. What kind of a tool would work well for this?
    Any advice...pleasssse?
    You may have to cut the outside of the spout off so you can hold the pipe coming out of the wall while you unscrew the spout. There are several tools to remove the strainer, ASSUMING IT WILL UNSCREW, but that is NOT a given. Too much force could snap the under tub pipe off and then you will have a "real mess". Sometimes you have to cut it out also.
  1. Toilet Flange Lid Stuck (1 pic)
    By zerolast in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-05-2011, 03:09 PM
  2. Stuck flange bolts
    By SteveW in forum Toilet Forum discussions
    Last Post: 04-08-2009, 10:17 PM
  3. Need Deep Shower Spout Flange
    By hartlbb in forum Shower & bathtub Forum & Blog
    Last Post: 02-18-2008, 10:02 AM
  4. Stuck lav drain
    By Guest in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-05-2006, 03:46 PM
  5. a very stuck tub spout
    By lostnewbie in forum Shower & bathtub Forum & Blog
    Last Post: 05-10-2005, 08:24 AM
