Pkin
I'm in the process of moving a drain in the basement of my 42-year-old home where the drain plumbing is under a slab. The pipe I was working on (a 2" shower drain line) was completely corroded through, so I started excavating. Now I've exposed the entire system near the project site, and its pretty much the guts of the drain system in my home.
Two Questions:
1. Should I replace everything since I have it open?
2. Should I switch to plastic or stay with the no-hub cast iron?
Thanks for your input!
Here is the original 2" pipe that was corroded thru the pipe bottom
After seeing the corrosion in the picture above I decided to check everything else in the vicinity, including the toilet. I didn't find any moisture in the dirt, so I suspect its not leaking. But now I have the problem: Should I replace this stuff while I have it exposed, potentially opening a can of worms (and disabling the home plumbing until it gets fixed), or should I leave it?
The tee that connected to the original shower line shows severe corrosion, but its solid.
Here's another view
Two Questions:
Here's another view
