Thread: faucet / toilet supply risers and stop valve preferences?
    DIY Junior Member Stu27's Avatar
    Sep 2010
    Northern Virginia
    Default faucet / toilet supply risers and stop valve preferences?
    I have a few final details remaining to finish up my master bathroom remodel. Faucet / toilet risers and stop valves come in several varieties and I'm wondering if there is a clear preference in the trade for one type over another. I have the following options available to me at the store:
    risers: chrome plated copper tube, pex tube, or braided hose (both steel braid and polymer braid). Is one riser type preferred over another? I was leaning toward the copper thinking it's stronger and that once it's installed you'd rarely need to mess with it.
    stop valves: sweat, compression, or push-connect (aka shark-bite). Is one stop-valve type preferred over another? I was leaning toward the compression stop valve because I'm concerned about the possibility of loosening the joint just behind the sheetrock in the soldering process and I don't know much about the push-connect valve's reliability (compression and sweat valves have been around and working reliably much longer).
    Many faucets come with their supply lines already attached, so you may not need to address that. I'd use 1/4-turn, compression stops.
    Plumber jimbo's Avatar
    Ask a dozen plumbers and you will get two dozen different preferences. Good theory about the solid copper, but that takes a little more skill, often need an expensive tube bender, etc. And it can be knocked out of wack by an errant vacuum cleaner, etc! I lean towards the polymer braided myself, but that is just me. Everyone has their fav.
    I suggest compression valves. Others will say threaded or sweat.
  1. Unique icemaker supply stop valve
    By locus123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-20-2010, 06:06 AM
  2. What's more likely, shared risers or separate risers?
    By mckern in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2008, 08:00 PM
  3. Leaking stop valve on sink and toilet
    By puechini in forum Toilet Forum discussions
    Last Post: 01-09-2007, 06:56 PM
  4. Leaking stop valve on 1st floor toilet
    By terripellatt in forum Toilet Forum discussions
    Last Post: 09-13-2006, 01:29 PM
  5. Toilet Stop Valve
    By mrtigre in forum Toilet Forum discussions
    Last Post: 05-11-2006, 01:31 PM
