Results 1 to 2 of 2
Thread: No water pressure!!!
    DIY Junior Member tthurston's Avatar
    Oct 2011
    Michigan
    Default No water pressure!!!
    I bought a cabin in July and the water system ran good. They system has an above ground pump. I had the water lines inside all replaced. I then noticed that the water pressure would drop after about 5 minutes in the shower. The problem has gotten worse. I replaced the pressure switch and the bladder tank with no luck. The pump constanly runs and I have no water pressure. I did notice that when I shut the valve between the bladder tank and the house, the pump shuts off like normal. With the valve open, I can hear noise in the pipe between the house and the bladder tank. Is this an indication that the line between the house and the bladder tank has a leak? Any help is greatly appreciated.
    Moderator valveman's Avatar
    Mar 2006
    You have a leak somewhere after that shutoff valve.
  1. Water Softener On = No Pressure, Bypass = Normal Pressure?
    By jsarin1 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-08-2011, 04:06 PM
  2. Could my new pressure balance valve be reducing my water pressure?
    By JenJen in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2011, 06:57 PM
  3. Changing water pressure on house pressure regulator.
    By kskier in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2010, 09:20 AM
  4. High Water Pressure Spikes on Well with Pressure Tanks
    By RayMan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-01-2010, 12:57 AM
  5. Water in well, pump working, can't build up pressure, but doesn't lose pressure????
    By bgnotaplumber in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-20-2007, 10:32 AM
