Results 1 to 4 of 4
Thread: Iron Removal Question
    DIY Junior Member jlbartley's Avatar
    Jul 2011
    WI
    Default Iron Removal Question
    This is probably less of a water softener question and a little bit more of a water treatment question. We've had our water lab tested and the results came back that we don't technically need to treat it with anything but the water when coming out of the bath faucets into the bathtubs appears a rusty color. I'm assuming this is iron. It also builds up in the toilets. We had it tested for iron but it came back at a level not requiring treatment but we'd like to treat it to remove the color.
    Here are the results from the water test
    Harndess 164 mg/l CaCO3
    Alkalinity 176 mg/l CaCO3
    Conductivity 336 umhos/cm
    pH 8.05 std units
    Saturation Index 0.1 Corrosivity Balanced
    Nitrogen-Nitrate/Nitrite 6.5 mg/l N
    Chloride 14.2 mg/l
    Iron 0.148 mg/l
    According to the infomration sent back from the lab nothing here requires treatment. We would just like to reduce the appearance of the rust colored water. Everything about the water tastes and smells fine. We would like to treat this ideally without softening the water. The water is not naturally hard and would prefer not to soften it further unless this is the only way to remove the buildup of the iron. Would love to hear your thoughs on our options. It seems like something like an iron curtain might be overkill.
    Thanks for your help!
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    At 164 mg/l, that is 9.59 gpg which is hard water. The scale for hardness is less that 1 to 10.5 gpg. If you don't want a softener and just want to take care of the iron, I would suggest a BIRM filter. BIRM stands for best iron removal media.
    Jul 2011
    WI
    Thank you for that information. I hadn't really realized that this was hard until I looked further after your comment. The information that I recieved from the lab stated that 150 mg/l CaCO3 was ideal with 200 mg/l requiring treatment. Would you normally recommend that we do install a softener for this? The water does not feel overly hard to us although we are experiencing a bit of buildup in our shower heads, etc.
    Nov 2010
    Ocala, Florida
    The numbers the lab provided is ideal for a pool or a spa but not your house water. A water softener will take care of the hardness and the iron.
  1. 3" Cast Iron Cleanout (in Wye? Removal
    By CapstanRec in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-21-2010, 11:48 AM
  2. Iron Removal for single tub.
    By Gast in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-18-2010, 10:01 AM
  3. Cast Iron pipe - Lead removal and resealing
    By tnr122 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-28-2010, 02:25 PM
  4. Softeners, resin, and iron removal
    By Ddanrr in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-04-2009, 08:42 PM
  5. Claw Foot Cast Iron Tub removal
    By nwnewbie in forum Shower & bathtub Forum & Blog
    Last Post: 08-23-2007, 08:13 PM
