Results 1 to 7 of 7
Thread: Stopper won't hold water in new bath sink
    DIY Junior Member polock's Avatar
    Oct 2011
    Virginia
    Unhappy Stopper won't hold water in new bath sink
    A plumber installed a new 19" round bathroom sink in the vanity. Same size as the old sink. We kept the same faucet and drain. The stopper is the lift rod to close drain, push rod down to open drain. The plunger won't hold the water in the basin. Called Moen, they sent a new plunger, and it won't hold the water either. The plumber doesn't know why. Has anyone got a remedy for this, a new sink that won't hold water is useless. Do they still make those old push in rubber stoppers?
    Feb 2011
    NW Ontario, Canada
    My guess is that it's leaking between the drain and the porcelain into the overflow cavity.
    Oct 2011
    Virginia
    do you mean the water's going out from under the metal drain collar?
    Feb 2011
    NW Ontario, Canada
    Yes. My guess is the plumber didn't seal it well enough. Easy enough to test with a $1 rubber stopper.
    Oct 2011
    Virginia
    Do you know how I can fix it? I'm a 66 yo female non-plumber.
    Feb 2011
    NW Ontario, Canada
    Assuming the stopper and the rod has been removed, do as follows:
    Loosen the jam nut under the sink so that the trim can be unscrewed from above. Roll some Plumber's Putty in your hands to warm and soften a finger sized length and form it into a donut under the trim. Screw the trim back into the drain. Tighten the jam nut underneath. Clean up the excess putty that will mush out from under the trim.
    Oct 2011
    Virginia
    You're right, I bought the plug and the water still seeps outs. I'm going to call the plumber to come back, he should have known that, he's been doing this for many years. My thanks to you for helping.
  1. Need O-Ring for Kohler Kitchen Sink Strainer/stopper - Where to buy?
    By DrToonz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-30-2011, 07:55 AM
  2. Pump won't hold pressure when running water.
    By sneetches in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-07-2009, 06:33 AM
  3. Toilet Tank Water Won't hold
    By jerome8283 in forum Toilet Forum discussions
    Last Post: 12-31-2008, 01:38 PM
  4. Broken sink stopper knob
    By maddfrog in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-05-2006, 05:11 PM
