Results 1 to 5 of 5
Thread: New Expansion Tank noise after somebody takes a shower or lots of hot water use...
    DIY Junior Member DoofusOfTheDay's Avatar
    Feb 2005
    Atlanta GA metro area
    Default New Expansion Tank noise after somebody takes a shower or lots of hot water use...
    I installed a new gas water heater(GE 40 gallon), and Watts(DET-5 2.1Gallon) expansion tank a few weeks ago. All is working fine, except I noticed that when somebody takes a shower or somebody turns on the hot water full bore like doing dishes in the sink, there is a little bit of noise coming from the expansion tank. It only lasts for a few minutes, kind of a groaning noise, like something hot inside cooling down maybe or maybe air settling? It has done this since the first day of install, I am just slow in getting around to asking about this. And you wouldn't hear it unless you are in the same room as the water heater. Maybe it is normal to hear a little noise from it after a lot of hot water get's used, I don't know. Thanks.
    Cheers,
    Gregg
    Expansion tanks generally do not make noises. Now, if the tank is not well supported, as the water level in it changes (the weight changes), it may be the pipes leading to it that are moving, and you hear that. The pipe (if the tank hangs down) need to be supported around the T to the tank. Or, the tank itself needs to be supported if it is horizontal.
    Dec 2009
    northfork, california
    The air pressure in the tank may be low and needs checking. These cheap beer cans often dont last long.
    Feb 2005
    Okay I can check the pressure which I set to about 45psi, which was same as pressure in house. I turn off water supply, open a faucet to let the pressure out then stick an air pressure gauge on the expansion tank to check it?
    Cheers,
    Gregg
    Quote Originally Posted by DoofusOfTheDay View Post
    Yes, all water pressure must be off to check the air pressure in the tank otherwise, the reading will be of the water pressure (if the water pressure is higher than the air pressure to start with). It is also a convenient place to check your water pressure as most people do have a tire pressure gauge, but may not own a water pressure gauge.
  1. Replies: 15
    Last Post: 06-06-2011, 04:55 AM
  2. Time hot water takes to reach shower....
    By Manicmechanic in forum Shower & bathtub Forum & Blog
    Last Post: 11-15-2010, 03:45 PM
  3. Pump takes 20 minutes to fill 35 gal tank.
    By kdwy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-16-2010, 07:59 PM
  4. Hot water tank expansion tank vs T&P valve.
    By Mikebarone in forum Plumbing Forum Discussion & Blog
    Last Post: 09-30-2008, 09:39 AM
  5. Draining Tank Lots Sediment!
    By molo in forum Plumbing Forum Discussion & Blog
    Last Post: 07-12-2007, 06:23 PM
