Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Need to break vacum in water softener drain line
  1. #16
    DIY Member rjh2o's Avatar
    May 2011
    Michigan
    The vacuum breaker is not necessary as stated by others. The vacuum breaker is actually creating back pressure on the softener valve when it is regenerating causing the NOISE you mentioned.
    RJ
  2. #17
    DIY Junior Member smithwd's Avatar
    Dec 2009
    Marlborough, CT
    Default Valve noise
    The noise was coming from the seat vibrating in the vacuum breaker...................
    someone said raise the water softener higher then the outlet......but that won't happen...........
  1. Constant Water flow through water softener drain line
    By Dale M. in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-23-2011, 02:13 PM
  2. Sewer line break in rubble-filled crawl space
    By neverenoughtools in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-21-2008, 11:57 AM
  3. Connect a new line to a water softener
    By marky in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-28-2008, 02:07 PM
  4. location of drain line for water softener
    By dony45 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-14-2008, 07:42 AM
  5. main water line break
    By flabbb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2007, 12:11 PM
