dersh16
Ihave this same mixer and need washers for replacement. Also when it goes back how are the plungers to be positioned when the spindles is put back in. Any help Thanks, Jack
Thanks for the great info. One other thing if you don't mind. The plunger on the right side I can push in but can't get it out to change the washer. Other than prying it out with say a straight claw hammer, any tip?? Thanks, Jack
Your valve is model B201 or B202 with washer joint sleeves or K-100R with ground joint sleeves. With an e-mail address, I could send a parts diagram.
The Question I have is: There is a Thumb Screw on the Lid, that when removed, allows access to the Little Screw on the Hot Shuttle/Plunger - what does that Little Screw do? Adjustment for travel of Hot Shuttle? Like a Stop Screw?
This is great news that this plungers are now available since I've been waiting 10 years to get a hot and a cold one. I search the Barry Walters site and didn't find any. Can you send me to the link so I can order these? Thanks ahead of time for the heads up!
May I have these 2 diagrams for these two models? I would like to see which model I have to order parts to it.Thanks,Your valve is model B201 or B202 with washer joint sleeves or K-100R with ground joint sleeves. With an e-mail address, I could send a parts diagram.
https://deabath.com/Faucet_and_Fauc...tub_shower_kits/standard_tub_shower_kits.html
Addendum: I am still not sure from the diagram as to what the difference is between a B201 and a B202. As stated above, the repair kit was improper.
Here is a link to the schematic for the B 201 and B202.
American Standard diagrams start on the tenth page of pdf
http://standardsupplyco.com/site/1591stan/Tub_Shower_Repair_Bath_Accessories_1_of_2.pdf
R1400 is on the 13th page
B201/B202 is on the 14th page
https://terrylove.com/forums/index....faucet-help-before-i-bugger-it-further.48894/[/QUOT
I think, I have something similar to page 14, but I will make pictures of all parts and will post them here. Thank you for your advise re: email.
Lizan
The difference between B201 and B202 is the size of the valve - both are identical in looks. B202 is the larger one and uses a fine thread plunger and B201 is the smaller one and has a course threaded plunger.https://deabath.com/Faucet_and_Fauc...tub_shower_kits/standard_tub_shower_kits.html
