Results 16 to 30 of 34
Thread: 1920's shower mixer - American Standard Re Nu ? B201 or B202
  1. #16
    DIY Junior Member 336flyerfan's Avatar
    Aug 2012
    Dearborn, Mi
    Default B201 Standard Mixing Valve
    Help!!!!
    I'm in desperate need of the cold plunger that goes with this valve. I have checked all over metro detroit to no avail. From my understanding, this part has been long out of production. I've been able to find two hot plungers, but, nobody has the cold side. Does anybody know where I can find one? Please email me Rclevel2@me.com
  2. #17
    DIY Junior Member jimmyp's Avatar
    Sep 2012
    Detroit
    been inside several times and always have trouble getting it back together correctly...
    any chance of getting a copy of the diagram?.. Is there a trick as to how you set the plumbers??? Out? In?
    also are these valves supposed to be a positive shut off or simply act as a mixing valve?
    any input you could give would be greatly appreciated....www.crzyftblhd@yahoo.com
  3. #18
    Sep 2012
    Detroit
    hi...could you please send me a copy of the diagram? Crzyftblhd@yahoo.com
    also is there a trick to putting it back together? Should it function as a positive shut off?
  4. #19
    DIY Junior Member Pumpguy1's Avatar
    Oct 2012
    Hi "hj",
    I too am looking to repair my ancient "Standard" shower. The pics posted at the start of this thread look identical to my shower. If you would be so kind, please send me a parts diagram to steveetzel@yahoo.com. Thank you!
  5. #20
    DIY Junior Member dersh16's Avatar
    Feb 2013
    New Jersey
    Ihave this same mixer and need replacement washers. What position should the plungers be in when putting it all back together Thanks, Jack
  6. #21
    Feb 2013
    New Jersey
    Ihave this same mixer and need washers for replacement. Also when it goes back how are the plungers to be positioned when the spindles is put back in. Any help Thanks, Jack
  7. #22
    Aug 2012
    Dearborn, Mi
    Plungers should be pushed in all the way and then turn the handle clockwise. The stem is a double threaded stem so if it doesn't shut off correctly the first time, turn the handle 180 degrees and try again. You can get the washers frome Lowes...you'll need to buy the Danco faucet repair kit. You'll find the washer you need along with a bunch of other stuff you'll never use but it's only $4.
  8. #23
    Feb 2013
    New Jersey
    Thanks for the great info. One other thing if you don't mind. The plunger on the right side I can push in but can't get it out to change the washer. Other than prying it out with say a straight claw hammer, any tip?? Thanks, Jack
  9. #24
    Aug 2012
    Dearborn, Mi
    Quote Originally Posted by dersh16 View Post
    Don't pry anything...the plungers aren't available at this point anymore and are made of bronze. I am in the midst of having plungers reproduced from a set of originals to help solve the majority of issues people are experiencing with this valve. Meanwhile, try Blaster from home depot. You could also sparingly try vinegar...just don't leave it on much longer than 10 minutes and flush with water. You're going to need patience regardless.
  10. #25
    Feb 2013
    New Jersey
    I got it out with some heat. I put an acetylene torch on it for a bit and it loosened up. I made the washers with what I could put together from a local hardware and it is up and running with no leaks. Thanks for everyone's help and suggestions Jack
  11. #26
    DIY Junior Member Jim Fleming's Avatar
    Sep 2013
    Pennsylvania
    Default B201 202
    Your valve is model B201 or B202 with washer joint sleeves or K-100R with ground joint sleeves. With an e-mail address, I could send a parts diagram.
    Could I please get that diagram/parts list?
    jfdogman@aol.com
  12. #27
    In the Trades Friend Dean's Avatar
    Jan 2014
    Baton Rouge, Louisiana
    I am in the process of making one of these Standard Shower Valves operational again - Name:  DSC07230.jpg
    Fully disassembled - Name:  DSC07299.jpg
  13. #28
    Jan 2014
    The Question I have is: There is a Thumb Screw on the Lid, that when removed, allows access to the Little Screw on the Hot Shuttle/Plunger - what does that Little Screw do? Adjustment for travel of Hot Shuttle? Like a Stop Screw?
    Last edited by Friend Dean; 01-02-2014 at 09:01 PM. Reason: added photo of Hot Shuttle
  14. #29
  15. #30
    Jan 2014
    Thank You - I actually downloaded this yesterday in the process of finding this forum.
  1. American Standard shower stem won't come out...
    By geronimo21 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-23-2013, 05:44 PM
  2. 1950s American Standard Shower Mixer Valve leaking
    By Btrandum in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2013, 12:43 PM
  3. American Standard shower valve
    By perrymiles in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-09-2012, 09:27 PM
  4. American Standard Max 1.5 gpm shower heads
    By jimbo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2011, 06:59 AM
  5. american standard shower drips
    By simoneaux in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2009, 07:49 AM
