Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: 1920's shower mixer - American Standard Re Nu ?
Hybrid View
    DIY Junior Member dradprice3's Avatar
    Oct 2011
    Detroit, MI
    Default 1920's shower mixer - American Standard Re Nu ?
    I have what i believe is an american standard shower mixer. I think its a re -nu standard but cant find any info or pics of this despite searching on Google extensively.
    initially it was leaking as the brass screw that hold the front plate on had corroded away. Replaced them and the gaskets with neoprene but when i reassembled i have a drip from the shower. The gaskets seem to be part of the two moving slides that are in the bores on each side. one is conical the other (hot?) has a bulb on the end.
    Can anyone confirm the type of mixer and details on the gaskets. I dont want to pry them out as i will probably damage the worse than the little drip I have.
    Any help gratefully received.
    Adrian
Size:  57.8 KBName:  Untitled-2 copy.jpg
    Your valve is model B201 or B202 with washer joint sleeves or K-100R with ground joint sleeves. With an e-mail address, I could send a parts diagram.
    Oct 2011
    Detroit, MI
    many thanks this is helpful!
    Oct 2011
    Detroit, MI
    anyone aware of a source for the o rings for these mixers?
    Brown's Partsmaster (www.BPIsite.com) should be able to help, although, if you have the old ones, and they are really "O" rings, (which I doubt since I do not think there were O rings in the 20a), any good hardware store should have them. Use the part number on the breakdown I sent and you will get the correct part.
    Oct 2011
    Detroit, MI
    Thanks. They weren't o rings but washers. I didn't realize the chokes unscrewed per the diagram. Thanks to you two 1920s showers are once again operational! Thanks!
    DIY Junior Member margox's Avatar
    Mar 2012
    NY
    Default Re-Nu Shower Mixing Valve
    I believe I have the same vintage American Standard Re Nu mixing valve on a shower. It appears it has failed because I can only get lukewarm water in the shower. Water is nice and hot in adjacent sink. Do you know where I could get one of the above model mixing valves? So far, I have been told the parts were discontinued a long time ago.
    You could certainly get lucky, but how many things 80-90 years old are there still repair parts available for? Sometimes it's hard to find some for 10-year old stuff (the limit car parts are required to be available, but since they often get reused, newer model years still use them thus extending their availability).
    DIY Junior Member joshdr's Avatar
    Dec 2011
    Wisconsin
    I have one of these and need a parts diagram if somebody could send me one. joshodoner@gmail.com.
    Thanks.
    DIY Junior Member waltm's Avatar
    Apr 2012
    pennsylvania
    I also have a model b201 or a b202 1920's shower mixer. can you please send me a parts diagram and where i can possibly order parts? waltermartzen@gmail.com
    Jul 2009
    North Vancouver, BC
    How do you know this so well. For years i have read your posts specifying exact parts and models. Do you have a photograhic memory? Or are you just organized?
    Quote Originally Posted by johnfrwhipple View Post
    John.... as an apprentice plumber in the '20s, hj installed some of those valves!. He has been smart enough over the years to save the paperwork!!!
    quote; as an apprentice plumber in the '20s
    You overestimate my abilities. My dad didn't let me start working on them until the 50's.
    Apr 2012
    pennsylvania
    I was wondering if you might have a diagram of a renu mixer with the shower jets if you could please let me know waltermartzen@gmail.com thank you
    DIY Junior Member jimmyp's Avatar
    Sep 2012
    Detroit
    been inside several times and always have trouble getting it back together correctly...
    any chance of getting a copy of the diagram?.. Is there a trick as to how you set the plumbers??? Out? In?
    also are these valves supposed to be a positive shut off or simply act as a mixing valve?
    any input you could give would be greatly appreciated....www.crzyftblhd@yahoo.com
  1. American Standard Max 1.5 gpm shower heads
    By jimbo in forum Plumbing Forum Discussion & Blog
    Last Post: 04-09-2011, 06:59 AM
  2. American Standard shower faucet identification
    By lazybone in forum Shower & bathtub Forum & Blog
    Last Post: 07-07-2010, 05:19 PM
  3. american standard shower drips
    By simoneaux in forum Plumbing Forum Discussion & Blog
    Last Post: 06-24-2009, 07:49 AM
  4. American Standard shower control leaking
    By allyner in forum Plumbing Forum Discussion & Blog
    Last Post: 04-02-2009, 09:57 AM
  5. American Standard Shower Valve issue
    By jsanfilippo in forum Shower & bathtub Forum & Blog
    Last Post: 03-25-2008, 07:50 PM
