Results 1 to 2 of 2
Thread: Enzyme drain cleaner vs Citrus oil based cleaner vs Bacterial based cleaner
Hybrid View
    DIY Junior Member Asiangem's Avatar
    Sep 2011
    Venice Beach
    Default Enzyme drain cleaner vs Citrus oil based cleaner vs Bacterial based cleaner
    I would love to have comments on the BioKleen Bac-Out Drain Care which uses only natural ingredients which are is enzymes AND NATURAL LIVE CULTURES; which is supposed to be more effective than just the enzyme type of drain cleaner.
    I've looked into InVade Bio-Drain which uses citrus based oils; also American Bio-systems Drain-Gel which uses concentrated bacterial gel which is suppose to contain more than 550 billion cells per gallon.
    I'm trying to get rid of the fruit flies/worms which have appeared in one of my tenant's shower drain...
    DIY Junior Member Curtis12345's Avatar
    Feb 2012
    Los Angeles
    Tarzana Plumbing been using Bio-Clean for about 15 years and it definitely does the trick in certain situations, where clogging is due to hair, sludge, dirt, waste or other material that has the tendency to build up over time. Other large objects will require, actual removal, or more high pressure devices such as hydro-jetting.
    Bio-Clean™ is an environmentally friendly safe drain cleaning solution. Powerful enzymes are used in the concentration of the substance, to ensure the effectiveness of the product. It is used as a regular maintenance product to prevent buildup along the walls of the drain pipes thereby preventing costly stoppages and repairs. Usually, within an hour after pouring, the enzymes begin to work and literally eat their way into the waste that has accumulated on the interior of your clogged drain. The enzymes disperse throughout your plumbing system and clean it completely.
    http://www.tarzanaplumbing.com
  1. HELP ! - Did a dumb thing with drain cleaner
    By BajaJoe in forum Drain Cleaning
    Last Post: 08-01-2007, 08:25 PM
  2. HELP ! - Did a dumb thing with drain cleaner
    By BajaJoe in forum Plumbing Forum Discussion & Blog
  3. PC-Cleaner registry cleaner to fix your errors
    By systemcleaner in forum Computers and Stuff
    Last Post: 03-03-2007, 07:03 AM
  4. Drain Cleaner & Fixture Finishes
    By sobersgea in forum Drain Cleaning
    Last Post: 11-03-2006, 10:03 PM
  5. Drain Cleaner & Fixture Finishes
    By sobersgea in forum Shower & bathtub Forum & Blog
