Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Delta monitor 17 series tub spout won't screw in adapter
  1. #16
    Quote Originally Posted by aviator8 View Post
    Hi,
    I was really hoping this was a lock nut tub filler as they are so much easier to install. What I am trying to puzzle out is; How do you determine how far out to solder the adapter? ?
    The instructions give a range for the distance from the wall....this range is what makes it so user friendly. \
    For bobl you don't use plumbers grease on o-rings. Bad for the rubber. Silicone grease is called for, and for a one-time deal like a tub spout, soap won't hurt.
    Plumbers grease is meant for metal parts, like stem threads,cloth-impregnated packing, bonnet threads, etc. It has been widely used as a general purpose lubricant, but in the "o-ring world" it is not appropriate.
  2. #17
    Mar 2011
    Long Island, NY
    Thanks Jimbo, I did not know that about plumbers grease. I guess then it is made from petroleum. And I thought all modern "rubber" items items are made from neoprene. Got to do some Googlin' now
  3. #18
    Mar 2011
    Long Island, NY
    Jimbo, I got out my tube of Plumber's grease I obught at Ace hdwe a while back at at least "it" says it is OK for O-rings. I guess there is other plumber's grease and not all O-rings are safe? anyway some pics attached here.
  4. #19
    In the Trades Plumber111's Avatar
    Feb 2012
    North Carolina
    Sounds like you're just getting the resistance of the o-ring and are scared to turn it further to get it on. You have other spouts if this one is damaged. Screw it on.
  5. #20
    In the Trades liquidplumber's Avatar
    Feb 2012
    Gastonia NC
    Quote Originally Posted by Plumber111 View Post
    HEHEHEHEHE..... thats exactly what i was thinking! Ive installed thousands of those spouts, yes really thousands. I love them.. sometimes the first thread or 2 is actually tightening up the plastic assembly inside the spout and it seems like maybe its gonna break. But keep going. use 2 hands and turn it. It isnt a loose sloppy fit, its fairly snug so it takes a little effort to turn it. I usually turn the valve on before I set the spout up against the back wall so that i can see if the solder job and o ring are actually sealing. if they dont seal, water will spray backwards thru the hole in the tub wall and soak the area behind the wall.
    It shouldnt take a wrench, but it will take a little effort to get it threaded on. and it usually gets a little easier after a few threads
  1. Delta Monitor Leak
    By annal_c in forum Shower & bathtub Forum & Blog
    Last Post: 07-18-2010, 11:50 AM
  2. New Delta monitor, no water
    By hciscott in forum Plumbing Forum Discussion & Blog
    Last Post: 01-09-2009, 06:51 AM
  3. Delta Monitor Install...Need Help
    By tilermike in forum Shower & bathtub Forum & Blog
    Last Post: 07-10-2006, 06:16 AM
  4. Delta Monitor Valves
    By Dunbar Plumbing in forum Plumbing Forum Discussion & Blog
    Last Post: 05-13-2006, 01:30 PM
  5. Delta Monitor Question
    By jammin in forum Shower & bathtub Forum & Blog
    Last Post: 03-19-2006, 09:41 AM
