Results 1 to 7 of 7
Thread: Black water after regeneration....
    DIY Junior Member Steve38's Avatar
    Oct 2011
    Phoenix, AZ
    Default Black water after regeneration....
    We live in Arizona - very hard water. We installed a whole house water softener about 5 years ago. Don't want to mention the brand name. The issue is that after the automatic cleaning, the water that comes from the faucet is black. We feel we are having to run the faucets longer each month until the water turns clear again. We have it serviced annually and there is never any issue. The company is telling us it's just carbon dust that has been mixed up and not flushed properly. Our water pressure at the house is probably around 60...semi-rural area of Phoenix. The first two years after the installation we never had black water...now it seems it's getting worse. The sediment in the toilet tanks is very fine like a dust. The bowls get stained and require a pumice stone to remove the stains. We are wondering, what is this doing to our appliances and clothes?
    Is this normal, or are we being fed a line of................?
    Thank you.
    Feb 2011
    NW Ontario, Canada
    Where would the carbon come from? Do you also have a carbon filter that you don't want to mention?
    If there is no carbon filter, I might suspect manganese and if so you might want to treat it separately.
    Oct 2011
    Phoenix, AZ
    We are told the Carbon is in the tank, put there by the manufacturer to filter out any chlorine. When the regeneration happens, the carbon gets mixed up and is just not flushing properly, but nothing is wrong with the system is what we are told.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    I have seen this before. The carbon is exhausted and needs to be changed. The unit does not rinse enough to clear the water after a regen. You either put up with it until all the carbon is gone or have it replaced.
    Oct 2011
    Phoenix, AZ
    The Water Softerner technician is telling us this is normal and that it's not clearing becuase our water pressure is too low, or our local Water Company is adding so much clorine to the water, that the carbon is really active. How do I convince them that the carbon is exhausted?
    DIY Member rjh2o's Avatar
    May 2011
    Michigan
    It sounds like manganese in the water. Take a raw water sample and have it tested. Carbon fines will NOT cause staining. Just black particles in the water. Manganese will have black particles and impart a grey tint to the water and stain toilets grey.
    RJ
    The carbon is being ground up by the resin and fine enough to go down through the resin bed and up the distributor tube out to the fixtures. That's why the dealer wants more water pressure, but that won't solve any problem, it will help grind up more carbon though. This is why it is a bad idea to mix carbon and resin.
    You should dump your resin and carbon into a few 5 gal buckets and using a garden hose, flush the carbon up and out of the buckets. Then reinstall the resin. Or buy new resin and replace the old.
  1. No regeneration - turbine problem?
    By SteveW in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-08-2011, 08:16 AM
  2. Digital water softener manual regeneration mode?
    By myaroch in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-11-2010, 08:53 PM
  3. Frequency of regeneration
    By TWEAK in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-16-2010, 07:54 AM
  4. Culligan water softener stuck on regeneration
    By shiv in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-22-2010, 07:41 AM
  5. Water Softener Regeneration
    By jbschaefer1 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-08-2006, 04:52 PM
