Results 1 to 5 of 5
Thread: Screw head in hot water supply ??
    DIY Member kstuart's Avatar
    Central Coast CA
    Default Screw head in hot water supply ??
    I can't figure this one out, so I am hoping that someone has an idea...
    Today, I turned the kitchen faucet to hot, and the flow slowed to a trickle.
    There was plenty of hot water at all other faucets, and no leak below the sink or under the house, so I removed the hot water supply to the faucet, and it also had virtually no flow even without the faucet at all.
    So, I removed the SS supply hose from the valve, and a small screw head popped out of the space where the hose connects to the valve !
    I hooked everything up again and it was now back to normal.
    So, where could a screw head come from - inside the hot water system ??
    Thanks !
    Feb 2011
    NW Ontario, Canada
    A retaining screw for a valve washer.
    Lots of possibilities and eventually something will happen and you will find where it came from.
    Central Coast CA
    This reminded me that the hot water heater was replaced several years ago, and the plumber also replaced an even older hot water valve at the time.
    So you are probably right.
    Over the winter, we were gone for a while and had the house winterized by a plumber who blew compressed air through the lines, and I'll bet that the screw which had sat around for years, was blown close to the faucet at that time.
    Now it makes sense, thanks !
    Dec 2009
    northfork, california
    Tell him to blow OUT of the house next time.
  1. I Found This Strange; screw found in supply tube.
    By dlarrivee in forum Plumbing Forum Discussion & Blog
    Last Post: 02-23-2011, 06:43 PM
  2. Hunter rotor head adjustment screw
    By vaman in forum Irrigation / Sprinkler Forum
    Last Post: 07-04-2010, 05:57 PM
  3. Is 1/2" PEX supply big enough for dual shower head?
    By KSHandyMan in forum Plumbing Forum Discussion & Blog
    Last Post: 06-24-2010, 10:48 AM
  4. Multiple shower head supply volume question
    By Photovor in forum Plumbing Forum Discussion & Blog
    Last Post: 01-12-2010, 03:00 PM
  5. Help! Shower Head attachment to water supply
    By Dongrungio69 in forum Shower & bathtub Forum & Blog
    Last Post: 12-07-2007, 07:37 PM
