Results 1 to 9 of 9
Thread: Replacing expansion tank on waterheater?
    DIY Junior Member gabby's Avatar
    Oct 2011
    s.c.
    Cool Replacing expansion tank on waterheater?
    Need to replace expansion tank on water heater. What do I need to do first besides cut valve off to expansion tank? The tank is full of water an laying over on its side. Any help will be appreciated.
    All you should have to do is turn off the water supply going to the expansion tank. The tank attaches to the water line with a screw adapter, so when you have the water off, you just unscrew the tank. Care, it will be heavy because it will be full of water. The new tank screws on the adapter and that's all there is to it except for making any pressure changes to the tank to match the PRV setting.
    Dec 2009
    northfork, california
    If its been full of water for along time and your T&P valve is not leaking, I would cut it off and throw it away forever.
    Feb 2011
    NW Ontario, Canada
    Full may be a relative term. Perhaps it's 90% full and the remaining 10% is saving the day.
    Quote Originally Posted by ballvalve View Post
    Let's not start this controversy again...IF you need an expansion tank by code for your specific conditions, install a new one. Those conditions are: a closed system (created either by a PRV or a check valve) or your local code requires one regardless. If you don't have a closed system, unless your local code requires one anyway (some do), then and only then, should you consider eliminating it. IF the system needs one by code or specific conditions, not having a working one puts constant stresses on your water supply system, decreasing the life of things. It is cheap insurance.
    I concur complete with jadnashua. I learned about thermal expansion tanks after I installed a PRV. Suddenly, my T/P valve was discharging water every time the water heater kicked on. I replaced the T/P (twice) and still have the problem. When I came to the forum with the problem and was advised to get a thermal expansion tank. I got one, installed it, and end of problem. Last time I checked, they cost about $50. If you can sweat a joint, they are simple to install. Just be certain it is well supported.
    Oct 2011
    s.c.
    Hey Thanks, I appreciate it very much. Sounds simple, just not want to mess anything up.
    Oct 2011
    s.c.
    Actually I picked one up at HD for $60.00 an got it home but it was larger than the one on the tank so I took it back today an got the right size for $38.95. I have a 80gal water heater so I did not think this was high at all. I plan on installing it tomorrow. Thank for all the help from both of you.
    The expansion tank should be sized by the WH and the volume of the lines modified by the temperature differential from the inlet to the outlet. It may be that the old one was too small. This will cause it to fail earlier since it would require the bladder to stretch further with each cycle. Watts has a sizing calculator on their website...you may want to check that out even if you use a different brand.
  1. Replacing Thermal Expansion Tank
    By waxgroove in forum Water Heater Forum, Tanks
    Last Post: 10-13-2011, 07:49 PM
  2. Replacing Thermal Expansion Tank
    By zaedrus in forum Water Heater Forum, Tanks
    Last Post: 10-12-2011, 07:11 PM
  3. Replies: 15
    Last Post: 06-06-2011, 04:55 AM
  4. replacing main, expansion loop?
    By Seattle38 in forum Plumbing Forum Discussion & Blog
    Last Post: 07-29-2010, 09:06 AM
  5. Hot water tank expansion tank vs T&P valve.
    By Mikebarone in forum Plumbing Forum Discussion & Blog
    Last Post: 09-30-2008, 09:39 AM
