Thread: Unicorporated Cook County Illinois Plumbing Code?
    DIY Junior Member Rev's Avatar
    Oct 2011
    oak forest, IL
    Default Unicorporated Cook County Illinois Plumbing Code?
    I have a house in Unicorporated Cook County Illinois . It was built to code in 1993 where requirements fo the waste pipe was cast iron. My question . Our cast iron pipe in the basement has cracked . Would replacing the cracked section\ with sch40 PVC pipe be in accordance with the Cook County plumbing code.? The home is a 2 story .
    Joe
    Joe, your best course of action is to call the county code office. While certainly there may be a plumber from Cook Country that frequents this forum, we readers are from every corner of the country and even some for Canada, the UK, and Australia.
    In the Trades wizdawiz's Avatar
    Apr 2011
    Chicago
    Default Current Code allows pvc in unincorporated Cook County, IL
    Not exactly sure when, but the code does not allow this substandard pipe in SFRs.
    So, yes, in your situation this would be allowed.
    Just remember, the only "long term" advantage of pvc is that the smooth interior lessens
    the likelihood of any material sticking to the pipe walls, provided the pipe is properly installed.
    You really should follow the manufacturers recommendations and ream both the inside / outside
    diameters and not over-glue, nor under-glue.
    The main point is this: since it is very likely the pipe will be rodded at some time, there is the
    increased chance of the pipe being rodded through. Even if this isn't the case, the smooth interior
    now becomes a very rough interior which is much more likely to catch hair and fats, oils, grease and
    anything else that finds its way into the pipe.
    That said, you really should post signs for the roto-rooter types which would probably dismiss
    such conditions as problems. It would be best to jet-rod, especially this section of pipe so as
    to avoid any future problems for yourself, or any prospective new owners. Make sure to use the
    correct couplings for tying the two materials together ! ! !
    Best of luck
  1. Illinois Plumbing Code
    By SewerRatz in forum Illinois Plumbing Code Questions
    Last Post: 05-30-2011, 06:44 PM
  2. Replies: 1
    Last Post: 01-09-2011, 08:13 AM
  3. Washing Machine/Toilet setup? Illinois Plumbing Code
    By James157 in forum Illinois Plumbing Code Questions
    Last Post: 07-02-2010, 10:06 AM
  4. Washing Machine/Toilet setup? Illinois Plumbing Code
    By James157 in forum Plumbing Forum Discussion & Blog
  5. Concern regarding GAS Cook stove???
    By 77TEXAN77 in forum Plumbing Forum Discussion & Blog
    Last Post: 04-27-2010, 04:07 PM
