Results 1 to 5 of 5
Thread: Copper Pipes Touching Each Other
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default Copper Pipes Touching Each Other
    Just finished the RO for the hot water Feed. Next is the cold water.
    Both are running parallel to each other horizontally.
    Where I go vertical to the drop ear, should I avoid the copper touching each other or is it okay to just lay both vertical and where one touches the other copper....just slip a small piece of pipe insulation between them.
    Nov 2010
    Maine
    Avoid them touching. In some cases electrolysis can occur and pin hole the pipe there. I would find something more substantial than paper, it will wear through. Perhaps a strip of plastic from a milk jug
    quote: In some cases electrolysis can occur and pin hole the pipe there.
    How can "electrolysis" occur when both are the same metal? Wear is a more likely cause of failure. Either solder the two lines together so they CANNOT rub against each other or insert a substantial piece of material between them and secure it tightly.
    Jun 2006
    I ended up using some 45's , 90s and just bumped it in/out
    Sep 2009
    Seattle. WA
    There are special copper fittings available for use in such situations, called "crossover couplings". Very handy in cases where
    it is desirable to keep the pipes in a single plane.
  1. Code Question: MC cable touching copper water pipe in ceiling. Problem?
    By PabNYC in forum Electrical Forum discussion & Blog
    Last Post: 11-21-2008, 11:24 AM
  2. Tree Touching Wires
    By molo in forum Electrical Forum discussion & Blog
    Last Post: 08-09-2008, 02:20 PM
  3. Copper touching black pipe
    By ToolsRMe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-17-2006, 06:37 AM
  4. To prevent copper from touching ductwork?
    Last Post: 09-27-2006, 04:37 AM
  5. Copper pipe touching pressure treated wood
    By britta in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-22-2006, 08:52 PM
