Thread: expansion tank connected to pressure release valve
    DIY Junior Member TeeDee's Avatar
    Oct 2011
    belleville, il
    Default expansion tank connected to pressure release valve
    As they would say on the radio, long time listener, first time caller.
    I'm installing a Peerless gas boiler (MI-04). It shows in the manual that I can hook up an air elimination device on the same pipe as the pressure release valve. Can I also connect the expansion tank to this pipe? I ask because this is the way is was installed in the house it was removed from. A 1 inch pipe that comes up for the top of the boiler to a T. The horizontal pipe off that T is the pressure release valve. The vertical pipe that continues extends 20 inches to another T. The pipe to the right of the T is the air vent and the pipe to the left of the T is the expansion tank. Is this okay? Thanks in advance. I will add photos if it helps...and if I can figure out how..
    Please add the photos. 800 pixels or less.
    The PRV needs to come off the main piping for the unit and so does the expansion tank. You need to make sure these are on the pressure side.
    Nov 2010
    Maine
    Yes you can as long as there are no valves between the expansion tank, the relief valve and the boiler itself
    Master Hot Water Mpls,MN BadgerBoilerMN's Avatar
    Mar 2011
    Minneapolis
    Careful here. The pressure relief valve (PRV) on any boiler and it's location are specified by the manufacturer. In general the relief valve is installed off a direct connection to the top of the boiler and nothing can be between the PRV and the boiler save pipe.
    There may be a tee off the top for an expansion tank but the boiler does not care where the expansion tank is, only the circulator worried about such things.
  1. Water well tank- Minimum Pressure Release Valve
    By Keith Robinson in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-24-2011, 02:38 PM
  2. Rannai pressure release valve leaking
    By shawndh in forum Tankless Water Heater Forum
    Last Post: 05-15-2010, 05:45 PM
  3. Best location for Thermal Expansion Tank and Pressure Reducing valve?
    By bobwood in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-10-2008, 07:15 PM
  4. tank valve - momentary water release
    By lhoward145 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-19-2008, 07:45 AM
  5. Is this a pressure release valve?
    By craniac in forum Irrigation / Sprinkler Forum
    Last Post: 05-12-2007, 08:08 PM
