Results 1 to 5 of 5
Thread: Shower valve identification. PP Avante
Hybrid View
    DIY Junior Member dbos's Avatar
    Oct 2011
    georgia
    Default Shower valve identification. PP Avante
    Can anyone help me id this shower control. It is about 19 years old. Hardware is solid and well constructed. The rest of the house is Moen, so I expect it to be of similar quality.
    Name:  021 (640x480).jpg
    Name:  020 (640x480).jpg
    Name:  019 (640x480).jpg
    Name:  018 (640x480).jpg
    Name:  016 (640x480).jpg
    The letters "SHWR" and the number 7105 or 7106 are cast on the mixing valve. I can't tell if it is 7105 or 7106.
    It is difficult to pull out and push in the handle. I think I need to replace the cartridge if I can determine the manufacturer.
    Thanks for you help
    DIY Junior Member Kait's Avatar
    Dec 2012
    Default Price Phister
    I have the same issue. It appears to be a Price Phister from my research, but it should have a letter between SHWR and 7105. Mine is H7105 and I am not having any luck. If yours is an E, you are in luck. Go here: Part number appears to be S74-292 for the Price Phister E 7105.
    Plumber jimbo's Avatar
    Thank you for an easy Christmas question...although if it was easy for you, you wouldn't have asked!
    Yours is a Price Pfister OX-9 valve, and the cartridge is the avante Pfister part # 974-292. Any markings on the valve itself are seldom of any help in ID. A PP engineer might identify them, if you could find one. But fortunately for us ( any ) plumber, this is one of the most recognizable valves and cartridges. I won' say most common, simply because it was not in production for very many years, but anyone who works in an area where PP was used by builders has seen a billion of them! You remove it by using pliers to unscrew the outer ring cylinder, then using the pliers to pull SMARTLY on the stem, it just pulls out.
    All the parts are readily available, including the handle and bowl escutcheon, possibly only in chrome, however. Danco may have them in brushed nickel.
    Santa Claus ( aka hj) must have been out late delivering, or he would have been all over this question!!
    Yesterday was a "recovering from milk and cookies" overload. People were supposed to be out visiting, NOT having plumbing problems. But, the Avante tub faucet was made for a LONG time, not just a few years, so there are millions of them in existence.
    "long time" is a relative term, and the avante doesn't compare to the Moen Chateau and Delta 600. The avante was squeezed in between the early ceramic 'flowmatic' and finally the OX-8. But yes, in certain areas, they were ubiquitous for a while.
  1. Price Phister AVANTE, removing mixing valve cartridge
    By TexasUltra in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-19-2014, 12:50 PM
  2. shower valve identification
    By lati_cz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-04-2013, 01:43 PM
  3. Price Pfister Avante. How to remove a stem from shower?
    By templeavenue in forum Shower & bathtub Forum & Blog
    Last Post: 08-16-2013, 01:04 PM
  4. Shower valve identification
    By guyinsb in forum Shower & bathtub Forum & Blog
    Last Post: 12-16-2012, 04:41 PM
  5. Valve Identification help.
    By HwTrader in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-08-2009, 08:54 AM
