I started typing the things that I knew that could cause these symptoms but after an hour of typing I decided to delete everything and just say several things could be causing this but I can all but bet you the well is not one of them.
Maybe it is time to call a professional.
My brother and I recently moved into a new home and its giving us some electrical trouble. This is whats happening. Ill be sitting watching tv and randomly the all the lights will start flickering sometimes the tv, oven, mirowave, satalite box will just shut off and come back on when the lights are flickering. I was outside last night and noticed the outside lights go off and on with the rest of the stuff when the inside lights flicker. A friend told us that hes seen it happen before. He said he thought it was happening because the wires going to the well are to small of a gauge so when it draws power it messes everything up. What would you guys expect the culprit to be?
