Results 1 to 8 of 8
Thread: Ada Ultramax...will it fit?
    P.E. (Professional Engineer) xlr8tion's Avatar
    Oct 2011
    SC
    Default Ada Ultramax...will it fit?
    I checked the Spec sheet on the ADA ultramax and it wants the h20 supply 5" off the floor and 6" from the base centerline.
    My current Kohlers have the water line at a height of 8" high and 6" off center.
    I know it wants 5" but will 8" work?
    If not I will go with the Drake II...it uses a 8" supply and is80 dollars cheaper with double cyclone and sanagloss (go figure no SG and ADA on the 1.6 U-max...) You have to go to the UMax II for both options.
    Thanks...
    Greg
    PS...I have a 3/8 connection..I see Toto want's 1/2.....
    There doesn't seem to be any reason you water supply location would be a problem. Water supply locations listed on the specs for toilets usually are suggested locations and are not finite. You say the water supply is 3/8", but I can assure you that if you really do have a supply valve that size, that it is connected to a 1/2" pipe and can easily be replaced, but even if you kept the smaller size, it might cause the refill to take a few seconds more, but would still work fine. If it was mine, I'd replace the valve with a new 1/4 turn model.
    Oct 2011
    SC
    Default Thanks Gary.....G-max vs. Double Cyclone
    Thanks and Great idea on changing out those 10 year old 4 turn valves....They seem they are going to fail(break) whenever I need to turn them off....or just fail and flood the home!
    Now the tough choice is between the Drake II and the UMax.....There is about a 50 dollar diff but the Ultramax does not, go figure, come with Sanagloss on the ADA height.
    The Drake II is spiffy enough looking to be on Toto's top page and comes with SG and ADA.
    The confusing part is you get bowl rinse with G-Max but not with Double cyclone; yet Terry is big on the UMAX II which uses Double Cyclone and has no bowl rinse..
    Any opinions...The Drake II looks as modern as the Two pieces come and as I said...can't get the ADA with Sanagloss in the Ultramax without going to UMAX II and then I lose the rinse of the Gmax....
    Doh...all this technology!
    Regards....Greg
    As long as the shutoff doesn't hit the trapway, you are fine. That means 3" or more to the left of the centerline.
    1/2" is the water in the wall, which you then install a shutoff, which most of the time is 3/8". But they also make 1/2 nominal and 1/2" IP sizing.
    The double cyclone rinses in a circular motion around the bowl.
    It also comes with Sanagloss (except in the black)
    For ADA you have the
    Drake II
    Vespin II
    Ultramax II
    Carlyle II
    Soiree
    Guinevere
    And others that can be searched for.
    And then you have the original Toto products that have the conventional straight down the bowl rinse.
    Drake
    Ultramax
    and others.
    I will be installing the Drake II in Sue's home this week. She likes that style and I like how it works.
    I'm pulling out a God Awful Home Depot brand that is flapperless and that she has previously tried to return to the store.
    The Drake II and the Ultramax II will flush like this video
    Oct 2011
    SC
    Default 1/2" it is....
    Thanks Terry!
    I mis spoke about the 3/8"...I was referring to the flex line off the POS valves I have that are on 1/2" male pipe.
    Yeah...I like the Drake II...I know its not a s "clean" as the Ultramax...but it ranks' #2 on your list and that is good enough for me!
    From your experience do the Drake II's perform as well as the Drakes?
    Thanks again.......
    BTW...I read the CR reports e-mail exchange...what a bunch of JackHoles...thank god I found your site or would have been stuck w/a Cimarron!
    Regards...Greg
    The Drake II works very well. That's why Sue is getting one.
    And besides, I have an ileostomy bag and I love how the double cyclone works for that. Many conventional toilets need to be flushed several times to rinse things out. The Drake II just nails it!
    On the CR thing. When my brother was with Ralph Nader, I sent those emails over, and it became a radio talk show topic with people calling in. The funny thing is that my brother personally knows the owners of that magazine. The owners had no idea that was happening though.
    Oct 2011
    SC
    You just hit 10K posts Terry!
    Congrats...The last decision is wherher to go w/the MS604114CEFG for only 60 bucks more than the Drake II....
    Thanks again Terry....
    Regards...Greg
    Oct 2011
    SC
    Default Pulled the trigger on 3 Ultramax II's....WooHooo!
    Now to get Kohlers un cemented from the tile on slab!
    Thanks for everyone's help...Especially Terry............
    Now I have to go take a $1100 beat down from the wife(better to ask for forgiveness then beg for forgiveness)!....
    Regards...Greg
  1. Toto Ultramax II / gwyneth vs Ultramax
    By Raven4065 in forum Toilet Forum discussions
    Last Post: 11-05-2011, 06:38 AM
  2. Replies: 5
    Last Post: 09-09-2011, 04:04 AM
  3. UltraMax ADA vs UltraMax II ADA toilets
    By x5md in forum Toilet Forum discussions
    Last Post: 02-15-2011, 06:49 AM
  4. UltraMax Toilet vs. Eco UltraMax
    By kturpin in forum Toilet Forum discussions
    Last Post: 08-19-2010, 04:34 PM
  5. Toto Ultramax, Ultramax II, and Eco Ultramax
    By Herrada in forum Toilet Forum discussions
    Last Post: 05-13-2010, 05:28 PM
