Originally Posted by
Gary Slusser
I'll say it again; If you size and program correctly, you can't get hard water before the next regeneration unless you use a lot more water than usual
and that is only possible with a control valve without calendar override; or not using it.
That is a function of the resin and the salt dose used which sets the K of capacity. Exceed the regenerated capacity and you start getting hardness through the resin. Then the more you run water the more hardness gets through. Then you must do 2 manual regenerations at the max of 15lbs/cuft of resin back to back with no water use during or between them to get the resin fully regenerated again.
