Results 1 to 8 of 8
Thread: Bathtub Big Trap is too low in basement ceiling
    DIY Junior Member dito74's Avatar
    Oct 2011
    Boston
    Default Bathtub Big Trap is too low in basement ceiling
    I have this big trap that it's coming down too low and I am trying to finish the basement.
    Everybody that comes down there tells me that this is not a good work, someone before me did this.
    What are my options? Can I replace it with another smaller trap? can I get rid of the trap? Thank you for the attention.
Size:  41.6 KBName:  IMG_5746.jpg
Size:  46.2 KBName:  IMG_5747.jpg
    1. You cannot "get rid" of A trap.
    2. That was a poor choice for a trap'
    3. Given the way the piping is installed even a proper trap will hang down at least the same distance.
    4. In other words, at "some" time the piping might have been installed to hide the trap, it does not seem possible now.
    There are smaller traps that can be used.
    You do need one though. Without the trap, you might as well put your nose down the outhouse and take a big breath.
    Feb 2011
    NW Ontario, Canada
    Put in a new trap up in the joist cavity and run the drain between and parallel to the joists over toward the exterior wall. Roll a 90 and join up to a wye with a cleanout that then runs under the floor joists parallel to the exterior wall over to the existing old drain.
    It still woudn't be to code since I don't see a vent anywhere.
    I would guess that out of the picture that there is a vent.
    You can't go up or down after the vent. It has to be at a 2% grade and within 5 feet on a 2" trap arm and 42" for a 1.5" trap arm.
    Oct 2011
    Boston
    Default thank you
    thank you guys, the idea to run between the joists to the wall and then along the wall is nice, but I am not a plumber and I don't know how easy that is going to be.
    I will probably leave it that way. I am going to have a kids room down there, 2 boys + 1 coming the next 2 weeks (that is also why I am in a hurry).... so I am thinking that perhaps I should at least protect this trap, in the case they decide to play baseball with it...
    is there some type of cover I can use/find? I guess after I put sheetrock maybe a plastic bowl (like there is a lightbulb inside) can do it.
    Feb 2011
    NW Ontario, Canada
    You cannot sheetrock that ceiling because that would create illegal hidden junction points in your wiring and you have wiring running under the joists.
    I guess that means you are a better electrician than you are a plumber. Anyone who would suggest installing a bathtub trap using an "S" trap, (especially connect to a VERY long drain line),would NOT be bothered by covering a concealed "J" box.
  1. Leak from 2nd floor bathtub through ceiling
    By krowton1 in forum Shower & bathtub Forum & Blog
    Last Post: 11-08-2009, 06:11 PM
  2. bathtub ceiling faucet
    By vu in forum Shower & bathtub Forum & Blog
    Last Post: 12-27-2007, 10:37 AM
  3. how much clearance should be between top of bathtub door and ceiling?
    By kren in forum Shower & bathtub Forum & Blog
    Last Post: 06-10-2006, 07:19 PM
  4. Gap between bottom of p-trap and ceiling?
    By plumberzcrak in forum Shower & bathtub Forum & Blog
    Last Post: 11-07-2005, 08:14 PM
  5. Shower & Bathtub leaking through the ceiling
    By MH in forum Shower & bathtub Forum & Blog
    Last Post: 07-26-2005, 10:43 AM
