Results 1 to 7 of 7
Thread: Insulation ok?
    DIY Senior Member Andrew21's Avatar
    Jun 2006
    New York
    Default Insulation ok?
    Hey all,
    I have a question.
    Is the insulation here ok? ( I did fill in the little void on the left hand side by the window..made sure of it!) This wall is against the outside wall and I just wanted to make sure that the insulation is ok before I screw it in and seal it up with Redgard.
    I'm worried that if I have to replace the shower valve that the torch will make the insulation go up in flames. But then again, I'm afraid of the pipes bursting behind the walls.
    p.s. I asked this on another forum. Sorry, just want opinions =)
    Aug 2009
    South*East
    If your in a cold climate, I wouldn't have put the valve on the outside wall. You could have used a right hand tub. It is a nice looking installation though.
    John
    It should be fine. Cutting down air flow is most important on an installation like this.
    You did NOT have to insulate the shower and tub spout lines because they are not "full of water" once the faucet is turned off. If you ever have to change the valve the wall insulation will probably be the least of your problems. If the water lines NEEDED insulation, then the elbows would also need it.
    DIY Senior Member TJanak's Avatar
    Sep 2009
    South TX
    If your fiberglass batt insulation is between the pipes and the outside wall (as it looks) I would not insulate the pipes. You want warm air from the interior to get to the pipes to keep them warm. As it is now you are blocking heat from the house from getting to the pipes.
    Kinda like when the say to open kitchen cabinets under the sink to keep the water lines from freezing.
    Travis
    When I need a precise measurement of something I often use the highly technical method of eyeballing it.
    Nov 2010
    Maine
    Never put pipes on an outside wall. Insulation does not create heat. Given time and cold enough temperatures the pipes and valves will freeze.
    Jun 2006
    New York
    Thanks for all the replies!
    Just to let you know the plumbing was there already. I was not going to move it because that would be too much work.
    Anyway, thanks again and tile on!
  1. insulation
    By ussfox in forum HVAC Heating & Cooling
    Last Post: 12-03-2009, 08:03 AM
  2. pex insulation
    By peltaz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-15-2009, 02:45 PM
  3. insulation
    By 7echo in forum Shower & bathtub Forum & Blog
    Last Post: 03-25-2009, 08:02 AM
  4. Pex Insulation
    By santanaf in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-25-2006, 06:18 AM
  5. Insulation
    By Cookie in forum Remodel Forum & Blog
    Last Post: 07-31-2006, 05:49 PM
