Results 1 to 11 of 11
Thread: Spray vs Air Injector for Aeration
    Non-pro Polymath Matt Helm's Avatar
    Apr 2011
    MO
    Default Spray vs Air Injector for Aeration
    I am putting together an aeration tank. I would like to avoid using a venturi air injector. So, I am planning on filling the tank from the top with agricultural spray nozzles (sized appropriately for GPM and PSI).
    Thoughts?
    Feb 2011
    NW Ontario, Canada
    How do you intend to put the air into the tank? How will you bleed air off?
    Apr 2011
    MO
    Filtered vent to the outside.
    As the tank is drawn down (by a jet pump that is charging the pressure tank), fresh air is drawn into the aeration tank. During the next fill cycle, air is expelled.
    I am hoping to avoid a powered vent, but it isn't a big deal if I can't.
    Feb 2011
    NW Ontario, Canada
    Ah, so... non-pressurized hold tank. Is the aeration to remove smell or to precipitate iron? If for iron, then your jet pump will clog up with iron and need frequent cleaning.
    Apr 2011
    MO
    Here is a very simplified overview. It does not show the air vent, filtration, or control circuitry.
    I threw this drawing together for a vendor that I was thinking of getting some parts from.
    Name:  Simple Aerator.jpg
    Apr 2011
    MO
    For hydrogen sulfide and some other noxious gas. It may be that elemental sulfur will also be an issue with the pump. That is beyond my knowledge.
    Edited to add: I am planning on multiple stages of filtration between the jet pump and the pressure tank. Coarser for elemental sulfur produced by the aeration and finer for some colloidal clay issues that I am still playing with.
    DIY Member rjh2o's Avatar
    May 2011
    Michigan
    The aeration/settling tank and any filtration needs to go AFTER the pressure tank. You can the use a Multi-Media backwashing filter to remove particulate matter. The way you have this designed at this point can potentially cause issues with the jet pump operation and pressure switch.
    RJ
    Apr 2011
    MO
    Quote Originally Posted by rjh2o View Post
    RJ
    How so? From the amount of oxidized iron?
    There may be rust buildup sufficient to block the jet in the jet pump. Cure... install a safety float controlled submersible pump in the aerator tank that comes on/off with the pressure switch on the pressure tank.
    Apr 2011
    MO
    I like it (I was going to have a couple float switches anyway).
    Ok to mount a submersible horizontally? Or, is that bad for the bearings/bushings/shaft?
    You can lay it on its side but they aren't made to do that so, since you'll have maybe 3-5 feet of useable water in the tank, I'd hang a 1/2hp 10-13gpm 240v a couple inches off the bottom so it doesn't stir up 'dirt' when it runs.
  1. Variable Volume Pressure Tanks and Aeration
    By howens in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-03-2011, 04:39 AM
  2. Cleaning/Replacing aeration tank strainer screen
    By sbarre in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-24-2011, 04:18 AM
  3. Air Injector question again vs Mazzi Injector
    By K Paterson in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-10-2010, 08:04 AM
  4. Air Injector Maintenance
    By joejvj in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-07-2009, 04:54 PM
  5. Sewage treatment plantís aeration system
    By charles21 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-20-2007, 04:22 AM
