Results 1 to 6 of 6
Thread: Sta rite pump for $75... Worth it?
    DIY Junior Member musicinabottle's Avatar
    Sep 2011
    sandpoint idaho
    Default Sta rite pump for $75... Worth it?
    I have the chance to purchase a one HP sta rite pump and starter for $75. Is it worth the money. It works fine and pumps water. Buy or steer clear?
    Moderator valveman's Avatar
    Mar 2006
    That is a really old one. Looks like the old oil filled type motor. Check the date code. It might last a while or it not run an hour.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    Our original Sta-Rite 1.5 HP pump lasted 28 years....on an 82 gallon galvanized tank that was completely undersized for the pump.
    But I would not give $75 for the pump.
    Sep 2011
    sandpoint idaho
    He's firm on the price. I walked away. There are many others out there to choose from! Thanks guys.
    Dec 2009
    northfork, california
    Always put a used pump ina barrell of water, run it, check the running amps as you close a valve to zero flow, then record the maximum pressure made. try it half shut and pressure at say 50 psi and measure the outflow in GPM. Now you know something.
    Jan 2008
    Virginia Beach, VA
    Wise decision! I have several 1/2 hp submersables that I would love to get $75.00 each. They worked when we pulled them and could last for years or they could die tomorrow!
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  1. 1 1/2 hp Sta Rite well pump pressure switch
    By RJB in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-16-2011, 07:06 AM
  2. Sta Rite 4" 110v 2 wire Deep well Pump
    By True Blue in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-31-2009, 05:04 PM
  3. constant pressure pump worth the cost??
    By crenduro@msn.com in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-19-2009, 07:23 AM
  4. Sta-Rite SND-L 3/4 hp
    By eldyfig in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-24-2009, 06:39 PM
  5. Sta-rite lawn pump
    By jimbo11 in forum Irrigation / Sprinkler Forum
    Last Post: 03-26-2007, 05:28 AM
