Results 1 to 5 of 5
Thread: SPRAGUE b-31R NATURAL GAS REGULATOR
    DIY Junior Member reevesjo's Avatar
    Oct 2011
    Indiana
    Default SPRAGUE b-31R NATURAL GAS REGULATOR
    Newbie here, but have a problem. Doing some re-piping on a nautral gas fired boiler in a radiant heating system my dad installed 50 years ago. I am fortunate to have a gas well on the property that produces 20 psi at the well. Just inside the home is this old, old Sprague regulator 3/4" NPT fittings. I want to replace it with 1" version. I am running new 1 1/4" polyethelene from the well to the house.
    1. Do I even need a pressure regulator with this low 20# pressure? There is plenty of volume. We never run out...yet.
    2. Is this Sprague the one to use?
    3. How do I set the pressures, with a psi gauge or manometer?
    The boiler is 140,000 input; 112,000 output
    40 gallon hot water heater
    kitchen gas range
    small space heater in one room
    Thanks for any advice, Joe
    Nov 2010
    Maine
    You have got to be kidding right?
    Appliances are designed for around 0.5 psi...20psi will damage things, and likely blow up the house.
    Nov 2010
    Maine
    1 inch of water [4 C] = 0.036 pound/square inch
    Nat gas appliances typically run on 7in.wc
    Oct 2011
    Indiana
    Default Dead serious, not kidding.
    Thanks Tom Sawyer. 7 inch water column is what I wanted to hear (or read). I can handle it with that info.
    Joe
  1. Bad pressure regulator?
    By dabensys in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-28-2010, 05:53 AM
  2. How to choose a pressure regulator?
    By redsoxfan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-20-2008, 03:31 PM
  3. Home water regulator???
    By Cybertrout in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2008, 06:03 PM
  4. Natural gas regulator question
    By footer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-30-2005, 07:39 PM
  5. watts regulator
    By eric in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-20-2005, 08:00 PM
