Results 1 to 5 of 5
Thread: Tape / dope on braided supply lines?
    DIY Senior Member DavidTu's Avatar
    Dec 2009
    Seattle, WA
    Default Tape / dope on braided supply lines?
    I thought I'd seen on the forum to NOT put pipe dope and/or plumbers tape on braided supply line connections... but now I don't find the reference. In any case... do these connections take dope or tape? My faucet instructions call for it but I've installed them w/o leaks and without tape or dope previously.
    What is best practice on this?
    Feb 2011
    NW Ontario, Canada
    Many of the braided hoses now have O-ring seals and as such don't need to be doped. If they use a metal to metal seal, a little pipe dope is fine but I would never use tape. IMHO tape is for sealing threads and on those hoses the threads don't do the sealing.
    Jun 2009
    Canada
    If it's a compression fitting, you don't use tape or dope.
    The compression ring/ferrule seals the joint, over tightening is also bad news.
    Tape and dope are for TAPERED threads, where the threads do the sealing.
    Plumber jimbo's Avatar
    Braided supply lines normally have a rubber gasket seal...tape would intefere. Some brands use a 'bullnose' which simulates an actual compression ring. It is for metal-to-metal seal, and again, NOT tape or dope
    Feb 2011
    NW Ontario, Canada
    THe problem with the bullnose is that it is of a much harder metal and so does not truly simulate a compression ring, which as the name implies, compresses to seal not only against the tube but also against the machined tapers. Any imperfection in the machined faces can cause a leak.
    And yet plumbers install them all the time without dope
  1. Recommendations on lav faucets that don't use braided supply lines?
    By Kimster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-30-2011, 09:07 PM
  2. Supply lines for water heater: Braided ones
    By ron in sc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-02-2008, 02:49 PM
  3. Can I use solder instead of tape or dope?
    By jhighley in forum Shower & bathtub Forum & Blog
    Last Post: 02-16-2007, 02:41 PM
  4. Pipe Dope vs. Teflon Tape
    By jamckelvey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-22-2006, 12:34 PM
  5. Pipe Dope On Teflon Tape?
    By PhilUpNorth in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-19-2005, 09:17 PM
