Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: Replacing old galvanized water supply line from meter to entry at house
  1. #31
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Not underground it would need to be brazed but soft copper can bend so there shouldn't be any need to add fittings.
  2. #32
    DIY Senior Member k9mlxj's Avatar
    Jan 2011
    Bay Area CA
    Above ground soldering should be ok for soft copper tubing? I guess I need to tape/sleeve the copper tubing where it goes thru' the concrete box/slab.
  3. #33
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Frankly, you are way overthinking this. From the photos you supplied, it looks like it is easy enough to bring in new service without messing with concrete and sleeves.
  4. #34
    If a galvanized water service is removed, the electrical panel must be grounded first
    http://www.kirklandwa.gov/depart/Fir...PageMode=Print
    Has the electrical panel been grounded after replacement of the water service?
    Sometimes the panel is grounded to the water service.
  5. #35
    Jan 2011
    Bay Area CA
    Thx I'm redoing the main electrical panel so would redo the grounding.
    A question:
    I'm thinking of possibly remodeling a few years later -- meaning I might need to move the water main entry location to the house to a different spot at that time.
    Would that be ok to move the soft copper line later on -- e.g. bend the copper main water line at a different angle only, but no need to extend the length.
  6. #36
    If it's soft copper, you may be able to get a little bend out of it.
    Copper gets stiffer each time it's moved.
  7. #37
    Do yourself a favor and pound some ground rods. Yes, you can bond the water pipes to the grounding system, but water pipes themselves should not be the system ground point. If you haven't already run the new supply line, and can accept it coming from a different location where you don't need to go underneath the concrete, there's no reason you can't bring it into the house there, then run it to the old supply point inside of the house.
  8. #38
    Feb 2005
    Omaha, NE
    Quote Originally Posted by Wet_Boots View Post
    To add to this observation, this thread is coming up on its two-year anniversary.
  1. Replacing exterior supply line to the meter
    By davesnothome in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-22-2009, 07:59 AM
  2. Replacing water line from meter to house...
    By gdog in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-03-2008, 10:35 PM
  3. Replacing Galvanized Pipes in whole house
    By tblackwell99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2005, 06:49 PM
  4. Guesstimates for new water line from meter to house
    By bronsonb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-10-2005, 07:11 AM
  5. Replace meter to house galvanized water line
    By SirZoltan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2005, 09:30 PM
