Results 1 to 5 of 5
Thread: Briggs R-7240 Tank
    DIY Junior Member sorrydangdog's Avatar
    Sep 2011
    Florida
    Default Briggs R-7240 Tank
    Can this tank be replaced anywhere....HD & Lowes do not carry Briggs? Anywhere else? Online?
    If it's a 3.5 gallon tank from the 80's then no.
    The best you can do is find a Briggs that someone is throwing out, or buy a new complete toilet.
    You would be replacing a builder grade $80 toilet that is decades old.
    Plumber jimbo's Avatar
    I believe that is a 3.5 gpf from the late '80's. There is NO tank which will bolt up correctly, or even if managed to getit on there, it wouldn't flush. Your bowl was really designed for 5 gpf, and they just reconfigured the tank to meet the 3.5, and those toilets never flushed right. If you tried to flush with 1.6 it would laugh at you,.
    Might I respectfully suggest you explore the Toto line of toilets? I know you are hoping to find an inexpensive fix for your problem, but you really have no viable options. Yes, you can buy another builder grade toilet for $100 from the box stores, but these are not good performers, and when you consider a toilet will be used by every member of your household several times each day, everyday of the year for the next 20 to 30 years, why would you want a toilet that would require frequent plunging and not always clear the waste when flushed just to save a few dollars?
    Sep 2011
    Florida
    Thanks guys. Have to squeeze it in between games and races this weekend!
  1. Briggs tank replacement
    By Bonesy in forum Toilet Forum discussions
    Last Post: 12-31-2011, 08:26 AM
  2. Briggs Toilet Tank cracked
    By princessmean1 in forum Toilet Forum discussions
    Last Post: 07-27-2010, 01:59 PM
  3. Replace tank on older 1.6gpf Briggs toilet or buy new toilet?
    By brennok in forum Toilet Forum discussions
    Last Post: 03-05-2010, 06:57 AM
  4. Briggs, Flush valve or flapper for old Briggs?
    By Guest in forum Toilet Forum discussions
    Last Post: 11-12-2008, 07:16 AM
  5. Cracked BRIGGS 4930 D Toilet tank????
    By somersetapt in forum Toilet Forum discussions
    Last Post: 06-01-2005, 10:48 AM
