Beachfront71
Hi and thanks.
We are dropping 2 vessel sinks on top of an old dresser we had refinished.
In order to try and conserve/use as much of the drawer space below the sinks I was loooking for some answers to the following:
1. Is there a minimum distance a ptrap should be below the drain hole of the sink?
2. Could I run the drain down 5 inches then elbow towards the wall, then put the ptrap in and go down to the ABS stub?
Any other suggestions appreciated! Using 1.5 compression fittings from home depot if it matters..
BTW. All of this will be inspected by the city.
Thanks again for any and all time spent/
