I had something like that happen yesterday, I believe. I was cleaning some junk from the attic in order to clear the way for the electrician when he comes, and I saw a clipped-and-taped end of a piece of old Romex hanging out of a box with no cover and laying loose up there ... and I decided to remove it and cover the box. Looking more closely, however, I also noticed another piece of old Romex connected to that wire inside the box and then running out and going down into a wall where an old mechanical timer is mounted, and I decided to remove all of that wire since that timer is obviously no longer in use or needed. After removing the cover from the timer, I checked for voltage before getting near any connections, and I saw something like 36 volts across the terminals in the timer ... and that means there must have been a very small "leak" at that clipped-and-taped end of the piece of old Romex hanging out of a box and laying loose in the attic ...
... and since safety is always first for me, I clipped the unneeded wires at the box by using a pair of insulated dikes while standing on a fiberglass ladder on a wooden floor before touching the terminals on that timer with anything other than my meter.
As an aside here: What was that timer about in the first place? It is a mechanical, 12-hour, wind-up timer with a mercury switch inside and its output circuit appears to have been clipped when a new furnace was installed many years ago, but it is definitely not a thermostat, just a switch. So, was there a day when furnaces were run with simple on-off timers?
, but I am a pro crastinator
