Results 1 to 7 of 7
Thread: Constant Water flow through water softener drain line
    DIY Junior Member Dale M.'s Avatar
    Sep 2011
    San Diego, CA
    Default Constant Water flow through water softener drain line
    Hi,
    I have an ecowater system 3000 R30 plus. I have recently had a continuous noise coming from the system. There is a constant flow out of the water in valve drain. I took apart the valve on the "water in" side. All parts there seem good and rings seem in good repair although the flow washer was not present. This is the first time I have removed these parts and the constant flow is new so it doesn't seem like this would be the cause. Any other thoughts as to why the flow would be continuous? Thanks.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    The constant flow to the drain is cause by the rotor seal. You may want to look at the outlet side as well. As for the flow washer, I've got a friend sending me a manual to refresh my memory (haven't worked on one since 1998). I have excess to parts if you need them. You can e-mail at affordablewtr@aol.com
    Sep 2011
    San Diego, CA
    I just bought a valve disc kit and replaced the inlet and outlet discs as well as the spider seals on both sides and three small o-rings....still didn't fix it. That was the fix recommended by ecowater tech support....not sure what else to try other than to call an ecowater guy out. Bummer
    Sep 2011
    San Diego, CA
    any other thoughts?
    Sep 2011
    San Diego, CA
    Oh, and the flow washer isn't supposed to have any effect....apparently its just a flow rate limiter but not a seal..
    Nov 2010
    Ocala, Florida
    Did you inspect the groove that the seal sit in to insure it was not broken? The only cause for the problem have I seen is: Rotor seal bad, rotor shaft cracked or seal groove broken.
    Service Contractor CESWater's Avatar
    Oct 2011
    Salinas, CA
    Also if the micro switch is bad then the unit will not find home correctly and the rotor may sit in a possition alowing water to flow...... 99 times out of 100 the cause of water running to drain is bad seal or cracked rotor shaft. on a very rare occasion you may find the main housing itself to be cracked, but that usually results in an external leak.......
    I just found this forum today.... I am an Ecowater authorized service person in Salinas, CA
    Please feel free to contact me with any questions.... I can also supply parts...
    Info@CenturyEnvironmentalServices.com
  1. Replies: 2
    Last Post: 04-09-2011, 05:21 PM
  2. Bladder to feed a cold water line that has low flow on city water.
    By FBXFixIt in forum Plumbing Forum Discussion & Blog
    Last Post: 09-17-2009, 09:58 AM
  3. location of drain line for water softener
    By dony45 in forum Plumbing Forum Discussion & Blog
    Last Post: 07-14-2008, 07:42 AM
  4. Water flow continues from hot water line
    By rick2995 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-12-2007, 04:30 AM
  5. constant flow control rather than constant pressure
    By mbartosik in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-28-2007, 08:44 AM
