Use some logic in determining what is/is not happening.
If the pump should be running and is not, are the points in the pressure switch open or closed?
Are the contacts clean or are they burnt and causing a voltage drop?
Have you set the bladder pressure properly given the cut in/cut out settings of the pressure switch?
