Spray-in foam insulation. You drill a small hole in the top & bottom of each 16" section. Two holes are used so you don't overfill the section, resulting in a bulged or damaged wall. A wand is inserted in the bottom hole nearly to the top hole (the foam is sprayed from the bottom). As the foam is released and expands the wand is moved down until is comes out of the hole.
