Mansfield tank-to-bowl gasket for hex nut
kurkevan
NJ
I am in the process of replacing a Mansfield 210 flush valve. The replacement valve that I got at Lowe's has a shank nut with a hex shape, while the nut on the old valve was round. My question is whether the gasket between the valve and bowl needs to be specially fitted to the hex shape. I have a brand new gasket that is similar to the old one, but when I put it up on the shank, the nut doesn't quite let it reach the tank bottom, and I'm not sure whether it will be leakproof after it's reattached. Any guidance would be appreciated, thanks!
Peterson
Active Member
PA
A couple of years ago, I rebuilt a an older Mansfield toilet. I used an American Standard tank to bowl gasket on the tank and it worked perfectly. However, instead of using the Mansfield flush tower, I opted for the traditional flapper style flush valve. It didn't affect the flushing of the toilet whatsoever. I know the Mansfield flush towers take a special tank to bowl gasket that is specially fitted for the flush tower itself. If there is a hex nut, I'd try an American Standard tank to bowl gasket.
