Thread: Valve clicking, but water not flowing.
    DIY Junior Member greenalfonzo's Avatar
    Sep 2011
    Arizona
    Default Valve clicking, but water not flowing.
    Hi,
    I just noticed that my sprinklers weren't coming on, so I looked and the display on my irritrol RD600 was blinking the accurate time. I adjusted the start time, and found that the water wasn't flowing when the system turned on. I then tried maually activating different valves through the control box without results.
    I then opened the box, and opened the the little plastic bleeder screws and the sprinklers all came on. I then switched the solenoids to different valves, and repeated the process getting the same results. I checked the solenoid & the hole under it and they seemed clean and functional. No water flow through any valve, and a lot of clicking from the solenoid on the new first run valve. Trying to run a different zone manually through the box just has the display flick to a flashing OFF.
    Thanks for any advice with this one.
    irrigation tech. mike1059's Avatar
    Jun 2011
    Portland, OR
    although it's very unusual for all the solenoids to go bad it's possible. first I would check the voltage at the clock, it should be 24v to each running station. if the voltage is good I would replace one solenoid with a new one and see if that is the fix. if the voltage is low the transformer or clock may have gone bad.
    Sep 2011
    Arizona
    Thanks for your help, Mike. I continued to switch the solenoids, and let the system sit for a couple days, and then it started running all four valves, but two ran very loudly, with a rattling buzz sound. This has gone on for two weeks, now it won't run again with just a clicking sound coming from the #1 solenoid. I'm going to try rewiring all the solenoids to make sure it isn't a water problem as the box was pretty damp. I'll buy a new solenoid and get a meter to check the voltage next.
  1. Problems with my fleck valve, clicking noise
    By acrod in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-11-2010, 09:49 AM
  2. Water softener making clicking sound.
    By martinG1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-18-2008, 07:21 PM
  3. Culligan mark 100 water softner water flowing to brine line all the time
    By seahawk99ca in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2007, 09:35 AM
  4. Low flowing water
    By Frank in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-14-2005, 01:02 PM
  5. Loud clicking from shower valve
    By DanW in forum Shower & bathtub Forum & Blog
    Last Post: 09-24-2005, 09:26 PM
