Results 1 to 5 of 5
Thread: Shower Pan Leak
    Default Shower Pan Leak
    I have a fiberglass shower pan in my basement shower which is leaking. After much detection, I found that the leak is from the joint that connects the drain to the pan. I have attached a picture.
    I wonder if there is some liquid sealent that I can pour into the joint which will eventually seal the joint. I cannot take the drain out with ripping out the shower. The original drain, I believe, is screwed from the bottom of the pan before installing the pan. I do not have access to the bottom of the pan with out removing the pan.
    I wonder if there is an easy fix for this...
    Jul 2009
    North Vancouver, BC
    Post(s) deleted by John Whipple
    The leak is probably between the pan and the drain fitting. A competent plumber would be able to remove it and install a "Wing Tite" drain fitting without damaging the shower pan or the downstairs ceiling. It will take a couple of hours however to get the old drain out.
    HJ,
    I am not sure if wingtite works in my case. Based on what I read wingtite drain is for 2 inch PVC pipes. My shower drain is connected to cast iron pipe which appears to be bigger than 2 inches...
    Pipes are spec'ed at the ID, not OD, so take that into consideration. It could be that they just put the shower over a floor drain, and there's no real connection. Hard to say without being there.
  1. Possible shower pan leak in sunken tub/shower
    By Estelle in forum Shower & bathtub Forum & Blog
    Last Post: 01-04-2011, 07:30 PM
  2. Leak from tub shower
    By ricksterv4n1x8 in forum Shower & bathtub Forum & Blog
    Last Post: 01-29-2006, 12:57 PM
  3. Shower leak
    By Lumber Jack in forum Shower & bathtub Forum & Blog
    Last Post: 01-05-2006, 11:04 AM
  4. Help with Shower Leak
    By MIKE42 in forum Shower & bathtub Forum & Blog
    Last Post: 10-26-2005, 06:38 PM
  5. Need help with shower leak
    By rinlud in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2005, 06:21 AM
