Thread: Has anyone build tub enclosure for kohler 5-ft mendota cast iron bath tub?
    DIY Junior Member DPTampa's Avatar
    Sep 2011
    Tampa, FL
    Default Has anyone build tub enclosure for kohler 5-ft mendota cast iron bath tub?
    Hello,
    I'm sorry to begin with what may seem to be an absolutely crazy idea leading to a general question. I have a bathroom with your typical
    standard style Kohler 5-ft White Cast Iron Bath Tub that is one-year old & rarely used. Budget prevents us from replacing the tub with one that is a drop-in acrylic type tub, but we would like to build a tub surround for this tub just as if it were a drop-in type tub. The actual surround
    will basically be a front and possibly a top that overlays the tub.
    Once the surround is built it will have a cement board surface, sealed with a liquid sealer, and tiled with marble or granite tiles to give that
    build-in custom look.
    Has anyone done this before and experienced success in the outcome? I realize it can easily be problematic and appreciate any input possible as to how I might go about building this and making it look quality.
    Thank you in advance for your help.
    Dennis
    Tampa, FL
    Can't really picture the problem. You know that there is a raised lip on three sides where the wall meets the tub. You don't have much width to work with.
    You would have to build a "raised" deck on the three sides to overlap the "tile flange" on the tub, and there would be NO good way to leak proof the front edge at the apron, since it does NOT have the tile flange, although you might get by with using the vinyl "tile flange" Kohler sells when you use a drop in tub in an alcove installation.
  1. Installing a Kohler Villager Cast Iron Tub
    By Terry in forum Shower & bathtub Forum & Blog
    Last Post: 09-09-2012, 11:08 AM
  2. Kohler Cast Iron or Americast???????
    By a.y1320 in forum Shower & bathtub Forum & Blog
    Last Post: 10-13-2010, 09:23 PM
  3. setting a kohler cast iron tub
    By captain5822 in forum Shower & bathtub Forum & Blog
    Last Post: 11-27-2009, 06:32 AM
  4. Toto vs. Kohler Cast Iron Tub
    By bathlady in forum Shower & bathtub Forum & Blog
    Last Post: 10-23-2008, 03:58 PM
  5. iron cast bath tub
    By linda in forum Shower & bathtub Forum & Blog
    Last Post: 02-25-2005, 08:45 AM
